2012 Lower Tail Lights Dead After Plugging In
Old Dec 2, 2013 | 11:22 AM
bmalicious's Avatar
bmalicious
Took the lower tail lights off to spray. Hooked them back in and only the reverse lights works on the lower assemblies. All other lights are fine. Just no Red Light on the lower assemblies.
Ideas?
Old Dec 2, 2013 | 07:20 PM
rkw's Avatar
rkw
Did they ever work? The red in the lower assemblies are the rear fogs. Does your car have the rear fog option?
Old Dec 2, 2013 | 07:50 PM
bmalicious's Avatar
bmalicious
It does not have a rear fog option. There are two bulbs in the housing. One comes on when you reverse ( behind the clear part of the lens ) and the other is just a normal tail light/ brake light.
The only ones that are working are the reverse lights on each one.
Replaced all of the bulbs. Same thing. All I did was unplug it and plug it back in.
Old Dec 2, 2013 | 08:04 PM
cerenkov's Avatar
cerenkov
Like the previous poster said, those are rear fog lights and came with bulbs from the factory. Unless you have the rear fog light option they never worked you just didn't notice it.
Old Dec 3, 2013 | 04:01 AM
nine5raptor's Avatar
nine5raptor
If they did work at one point as a brake light/tail light then someone has wired them into the brake lights. I have mine like this using the add-a-brake kit from outmotoring.
Old Dec 3, 2013 | 05:43 AM
bmalicious's Avatar
bmalicious
Thanks.
I probably just didn't notice. Figured they were functional as a tail/brake light.
Sexual Chocolate
Mar 31, 2019 08:02 PM
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
