Compression test results
Old Nov 16, 2013 | 07:23 PM
jvw's Avatar
jvw
Dry 157 147 154 152
Wet 173 167 167 162
Engine was at operating temp. R53
The pressure for #4/wet was somewhat surprising to me so I double checked it.
#2 is almost %15 greater for wet than dry; but both wet and dry numbers range no more that 7% to each other.
Overall, the numbers seem reasonable to me. Any thoughts?
I had had some codes for random misfires and a pending code for cyl 2 misfire so I decided to check out the plugs and do a compression test. The plug tips look reasonable (for ~73k) but plug 2 had a lot of oil on the outside and plug 3 had some oil sludge. I'm assuming it is the seals to the valve cover so I'll be replacing the valve cover gasket and seals soon.
Old Nov 17, 2013 | 05:00 AM
mrbean's Avatar
mrbean
The comp numbers don't look too bad. I would go ahead and replace the valve cover gasket and throw in a new set of plugs and wires. It may not solve the misfire but you're about due for replacement anyway.
Filmy
15
Jun 6, 2023 06:27 AM
cinq
GP Talk
Sep 14, 2015 05:32 AM
Suspension Products
Sep 10, 2015 11:46 AM
Sep 3, 2015 02:06 PM
