Engine Temperature
Old Nov 11, 2013 | 05:10 AM
windfall's Avatar
windfall
Engine Temperature
It this is covered elsewhere, let me know, but I couldn't find it.
I have an 09 Clubman S. It has started to run cold in the winter. For the first two years, the winter engine temperature was about the same as the summer. Of course, if I am flogging it, it does its computer-aided cool-off from about 215 to 180. Last winter and this winter, the only way to get the engine over about 165 is to let it idle, or drive slowly. The service people say it is OK, but the fuel mileage goes down, so I think that the computer is calling for more fuel, as it sees a cold engine. Suggestions?
Old Nov 11, 2013 | 12:17 PM
bikerbob951's Avatar
bikerbob951
First instinct is thermostat failed in the open position, have you verified that the thermostat works correctly?
Old Nov 11, 2013 | 03:03 PM
CHKMINI's Avatar
CHKMINI
My current N14 runs between 222 and 227 regardless of the outside temperature. My previous N14 operated exactly the same. +1 on either a thermostat issue or the aux.fan is running continuously.
Old Nov 11, 2013 | 03:15 PM
v10climber's Avatar
v10climber
Yep that's not right. First guess would be a bad thermostat
Sent from my DROID RAZR HD using NAMotoring
Old Nov 11, 2013 | 08:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That is a perfect description for a failed thermostat. It's been a common failure on the R56 cars.
We have a few left in stock as they were on backorder for months
http://www.waymotorworks.com/thermos...5-r56-r57.html
Old Nov 12, 2013 | 05:03 AM
windfall's Avatar
windfall
If this was not German, I would suspect the thermostat, but I was told that the temperature was also controlled by the computer on the Mini?
Old Nov 12, 2013 | 05:04 AM
windfall's Avatar
windfall
Why do you suggest the whole assembly if only the thermostat is faulty?
Old Nov 12, 2013 | 06:49 AM
InjectedGT's Avatar
InjectedGT
From the look of things the entire housing is all one unit. No stand alone thermostat in there. It's integrated. If I'm wrong on that, the thermostat housing is one of the most common failure points on these engines, so you should change it while you're in there anyway.
Old Nov 12, 2013 | 06:58 AM
nine5raptor's Avatar
nine5raptor
Had this experience for the first time today. Got the car in July and it has always shown 221-227. Today it was 19F out and after my 27 min commute (mostly highway), I was at 177. Heat was on medium, not blasting. Watched it creep up to that slowly the whole way in. If I had run longer, it may have climbed more, but it was very, very, very slow rising.
Old Nov 12, 2013 | 08:24 AM
windfall's Avatar
windfall
Sorry, I am used to older cars that have housings and parts that last. I believe that the Germans have made a part that does not last. I has a Passat and the catalytic converters went at 70,000, so a thermostat housing that goes at 40,000 should be no surprise. I just think it is a poor way to build a car. I guess it is a way to charge more, because there is no other reason I can think of.
Old Nov 12, 2013 | 09:04 AM
nine5raptor
I just replaced the thermostat (last week) on my 05 envoy. It is also a housing type setup, ~$100, and went at 82k miles. Just a current trend in auto making it seems.
TREX
Nov 2, 2019 07:31 PM
finn
Aug 21, 2015 07:59 AM
tylewis
Aug 18, 2015 06:53 AM
PSIChocolate
Aug 13, 2015 12:46 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
