Shut-off Valve / Bypass Valve mafunction will throw code?
Old Mar 23, 2013 | 11:08 AM
Hochspannung's Avatar
Hochspannung
My bypass valve sticks pretty badly. At least, that't what I believe is happening.
When I depress the accelerator, I have at least two full seconds before I get any boost. So my S/C is behaving like a big turbo.
If I hook it up to a code reader will it throw a code for that ?
Old Mar 23, 2013 | 11:49 AM
ZippyNH's Avatar
ZippyNH
Generally no....
If the bellows that connects to the vacum line fails..maybe, but due to a vac leak, not due to a sticky bypass valve.
You can try to ziptie the bypass valve closed, and see if you lag goes away...you loose some mpg, but easy test.
Old Mar 23, 2013 | 12:08 PM
Hochspannung
just zip tie that external lever that you can work open and closed by hand?
Old Mar 23, 2013 | 12:12 PM
Hochspannung
when the car is off, the valve is in closed position correct?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
wkp1219
Nov 13, 2015 07:52 AM
Jacob Kenney
Sep 1, 2015 10:22 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
