It's FREEZING and my R56 is sputtering
Old Jan 28, 2014 | 10:36 AM
  #26
You are welcome, If you have it already you will have the little tube coming off the back of the valve cover and going right before the intake near the valve.
Old Jan 28, 2014 | 10:40 AM
  #27
dudebaker's Avatar
dudebaker
I saw that in the thread you linked, and it doesn't look familiar. I'll double check after work.
Old Jan 28, 2014 | 06:08 PM
  #28
Eddie07S's Avatar
Eddie07S
Dudebaker,
You should also be able to go to a dealer and have them check the MINI records for this. I would have thought that they would have changed over to the new design by 2010, but maybe MINI hadn't gotten it into all of them by then. I had the problem on my '07 and it was fixed in '09. What I don't remember from my '07 was whether this was a "total" fix or a "most of the time, if it doesn't get too cold fix". The reason I say this is I have a vague recollection that it is the latter.
Also, there is a debate on another thread about the effectiveness of OCCs. When it is cold and the engine is cold, the amount of moisture produced is probably more than the OCC can handle. Not that it has been cold where you are. Besides, the ice block forms after the car is shut off and the moisture condenses in a bad spot. There is nothing to force the moisture through the OCC like there is when the car is running.
Let us know what you find out.
Old Jan 28, 2014 | 06:46 PM
  #29
dudebaker's Avatar
dudebaker
Thanks Eddie. Looks like I do have the cold weather manifold. I suppose I would be throwing p1637/38 a lot more often if I didn't. I hear what you're saying about the OCC. Hopefully this frozen throttle thing is just a "once in a while" annoyance.
Last edited by dudebaker; Jan 29, 2014 at 03:46 PM. Reason: I don't have the cold weather manifold.
Old Jan 29, 2014 | 07:34 AM
  #30
dudebaker's Avatar
dudebaker
Alright, she popped P1637 and P1638 again this morning. I let her warm up to above freezing, shut down and restarted twice, and she was back to normal. Cleared the codes with the ScanGauge and drove to work. In these driving conditions (cold and avging 20 mph) the coolant temp only warms up to ~160 degrees on my daily commute. Perhaps not reaching normal operational temps is causing the issue? Thoughts?
Old Jan 29, 2014 | 10:18 AM
  #31
flashlightface's Avatar
flashlightface
dudebaker-
Sounds like your thermosat is not closing/recycling properly. Mine runs at 225f all the time- I have a scan gauge II installed also-
good luck,
Old Jan 29, 2014 | 11:19 AM
  #32
dudebaker's Avatar
dudebaker
Originally Posted by flashlightface
dudebaker- Sounds like your thermosat is not closing/recycling properly. Mine runs at 225f all the time- I have a scan gauge II installed also- good luck,
No, I doubt there's an issue with my thermostat. Mine does run at ~220 when I can drive at normal speeds and not in temps well below freezing. Like I said, it's been consistently 20 below freezing here for the past few weeks, and I rarely reach speeds over 20 mph on my daily 15 minute commute to work. When traffic is heavy, my commute can take up to 45 minutes, in which case the coolant temps do reach ~220.
Old Jan 29, 2014 | 03:48 PM
  #33
dudebaker's Avatar
dudebaker
Turns out I'm an idiot, and do indeed have the normal weather intake manifold. I compared the photos directly to my manifold and PCV hoses, and it is definitely not the reworked "cold weather" manifold. Seems odd, considering it's a '10 that was sold new in Michigan. I wonder is the PO dealt with this problem, and what they did. Anyway, I'm thinking an additional OCC is a possible quick and easy fix.
Old Jan 29, 2014 | 04:00 PM
  #34
nine5raptor's Avatar
nine5raptor
I don't have the new intake either down here in MO on my 10. I've popped the code once this winter.
Sent from my XT926 using NAMotoring
Old Jan 29, 2014 | 04:19 PM
  #35
dudebaker's Avatar
dudebaker
It appears Mini will install one under warranty, if you still have coverage. My warranty coverage just expired before this started happening.
Old Jan 29, 2014 | 04:38 PM
  #36
Eddie07S's Avatar
Eddie07S
dudebaker-
good luck,
For really cold weather this coolant temp is pretty normal. This is typically what I have seen and my thermostat is good (at least according to the dealer). BTW - my '07 ran at 225f but my 2012 runs at 215f when it is fully warmed up.
Also, I would push on the dealer to do the replacement under warranty. This is a known MINI problem.
Old Jan 29, 2014 | 05:49 PM
  #37
nine5raptor
I have 2k mikes or until April left.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Sep 4, 2015 01:32 PM
Sep 4, 2015 01:31 PM
