No compression cylinders 1, 2, AND 3 - What would cause this?
Old Dec 13, 2012 | 09:57 AM
  #26
Slave to Felines's Avatar
Slave to Felines
Originally Posted by DVUS CPRS
I guess I'm just use to the Japanese/ Korean cars I've had in the past that take forever to have a problem, and run forever. Boring as hell to drive though.
Take a look at some of the Honda CRX forums some time. You'd get the distinctly opposite impression there--that at least one type of Japanese car is an unreliable POS that is fun as heck to drive... Even though some of us have run nearly a quarter-million miles on those cars without serious issues.
Old Dec 13, 2012 | 11:56 AM
  #27
MNIPWR's Avatar
MNIPWR
So MNIPWR, are you saying the more mods I throw at ol girl, the more of a foul mannered stuck up preppy girl she'll become? LOL!! That's not good.
Pretty much.
Old Dec 13, 2012 | 01:25 PM
  #28
aklucsarits's Avatar
aklucsarits
Can't tell if serious.
Being that the CRX was last sold in 1991, the newest Honda CRX you will find is over 21 years old today. But the Honda CRX in particular has a legendary reputation of reliability. There are many CRX survivors still alive today with hundreds of thousands of mile on original drivetrains that have never been opened up once.
But in general it would not be surprising at all to have a few engine issues with a sampling of surviving 21+ year old cars, especially ones with a few hundred thousand miles on them. I would argue however that it IS surprising to find a 5 year old car that cannot even achieve 50,000 miles without major engine failure, which is exactly what we seem to have on our hands here...
Old Dec 13, 2012 | 01:45 PM
  #29
MNIPWR's Avatar
MNIPWR
The new Subaru's are having issues with ring lands snapping/premature ring wear. Same issues we have.
Old Dec 13, 2012 | 08:39 PM
  #30
DVUS CPRS's Avatar
DVUS CPRS
I was going to say exactly that! I had a friend in college back in 2000 that had a CRX previously owned by 3 people I think he said, and that thing ran like a champ. All he did was drive it for the years he owned it. Engine and trans never touched except the regular oil changes and tune ups. Hondas are like Toyotas, but with reliabilty AND personality.
So to say it's expected to have engine issues after only a few years still makes me think something/ someone's slipping in the reliability research department. I bet if BMW produced their own badged 'MINI', the problems would not exsist as they do.
Old Dec 13, 2012 | 08:59 PM
  #31
Azminispeedin's Avatar
Azminispeedin
You could have bought a generally more reliable Japanese car but you didn't. Many of the same reasons apply to the guy who buys a porshe or Ferrari instead of something like a GTR. Pay for your repairs or educate yourself on the needed repairs or just buy a corolla and call it a day.
Old Dec 14, 2012 | 09:28 AM
  #32
Slave to Felines
... There are many CRX survivors still alive today with hundreds of thousands of mile on original drivetrains that have never been opened up once.
Correct! But if you read the forums (at least, at the wrong time) and used that as your only source of information, you might get the impression that they were unreliable POSes.
But in general it would not be surprising at all to have a few engine issues with a sampling of surviving 21+ year old cars ...
True, that is a separate issue. But I was addressing the idea that forum posts about problems == unreliability. I picked the CRX because it is a subject I am very well acquainted with, having spent the better part of 20 years driving one.
Old Dec 22, 2012 | 03:58 PM
  #33
MNIPWR's Avatar
MNIPWR
More info for you. There were signs of overheating in my engine. You could of had the same thing. However, you lost three pistons and I only lost one.
Old Apr 4, 2014 | 08:48 AM
  #34
KMoDizzel's Avatar
KMoDizzel
I have a 2007 MCS - Stock with JCW tuning kit dealer installed a few months ago. Car has less than 50,000 miles on it.
My car was always running fine, no noises. No symptoms. Made good power. I parked it in my garage about 1 week ago. I went to start it yesterday, and it would crank but not start. My first thought was battery going bad, but I could not jump start it.
It started to sound like maybe it needed another new HPFP after that. It's already on its second. I had to get it flatbedded to the dealer this morning. Was hoping for the HPFP to be the bad part so it would be warrantied...
Dealer just called and said they did a compression test and found zero compression on cyls 1, 2, and 3. How could that possibly happen? And what could have caused that? The car was running fine when I parked it in the garage... Nothing was leaking from the car either.
They want $1300 to take off the head and diagnose further.
What was the result of this problem? You never updated after the head was removed. I may be in a similar situation.
Old Sep 17, 2014 | 01:49 PM
  #35
justawatcher's Avatar
justawatcher
hmm, yes, what happened?
2008 mc 12
I may be in the same boat... 0 on 1,2,4 normal on 3.
- oil is full and clean,
- pressure tested radiator, ok
- cams are turning and chain guides are intact.
thinking from reading that the crank bolt / chain drive slipped.. will check it in a few days when the tools arrive
Old Sep 22, 2014 | 08:04 PM
  #36
justawatcher
2009 not 08 mc N12
Update.
Well got the cam tools and checked the alignment and found all to be in good order.
The valve train components appear to be intact and functioning. Pulled the intake manifold and found valves to be moving but not seating/sealing. they don't appear to be bent but instead it appears to be a possible seating problem.
Any suggestions before pulling the head?
Old Jun 10, 2015 | 11:43 AM
  #37
justawatcher
Update.
Replaced the engine and just got around to checking out the old engine..
It had ingested a small nut.. then shared it with two other cylinders..
kudos to the last guy to work on it for allowing me to buy a great car on the cheap.
Fordgt4
Oct 10, 2015 10:42 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
SneedSpeed
Oct 1, 2015 03:01 AM
silence2-38554
Sep 28, 2015 12:19 PM
