How to adjust camber on mini's
Old Mar 28, 2004 | 05:47 AM
VCARUSO15's Avatar
VCARUSO15
Hi I am a manager at a private auto repair faculity and have a customer with a mini that I wants to adjust the camber settings. I have searched all my software and can find no information on adjusting camber. Is there camber adjustment on these vehicles and if so what is the procedure for adjustment. Thanks for any help.
Old Mar 28, 2004 | 05:54 AM
paulmon's Avatar
paulmon
I know for a fact that the rear can't be adjusted and I believe this applies to the front too. The only way are a set of camber plates in the front and camber control arms in the rear.
Paul
Old Mar 28, 2004 | 05:58 AM
2Cool's Avatar
2Cool
Yep, no adjustment on the MINI except for front toe.
It takes camber plates up front and control arms in the back to make it adjustable. Can't even do the eccentric crash bolt trick in the front like most other cars, the spindle mounting design doesn't allow it.
Old Mar 28, 2004 | 06:07 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Stock MINIs cannot adjust rear camber.
The best and easiest way to adjust rear camber in a MINI is by using adjustable rear control arms (lower pair).
Rough cost is about $240 to $298+ for parts.
http://outmotoring.com/bmp_promini_a...trol_arms.html
http://outmotoring.com/alta_adjustab...trol_arms.html
Or for a set of four lightweight rear control arms for $355 consider these from RDR
http://www.helix13.com/html/products/suspension.htm
Old Mar 28, 2004 | 08:32 AM
2Cool's Avatar
2Cool
Or buy the RDR ones directly from them for $335... hey, $20 is $20 ya know...
Old Mar 28, 2004 | 11:38 AM
VCARUSO15's Avatar
VCARUSO15
I didnt think so! Thanks alot
Old Mar 28, 2004 | 06:11 PM
flyboy2160's Avatar
flyboy2160
according to the tis, the rear toe can be adjusted by loosening the front attach point of the rear "trailing" arm.
flyboy2160
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
Aug 7, 2015 09:51 AM
OutMotoring
Aug 6, 2015 09:32 AM
