2002 mini codes p0222 p0123-
i may have posted my first thread in the wron area-
i just bought this car always wanted one had in one the road for a day and it craps out
went to the car after work tired to start it - almost started the sounded like it stalled. just cranks now wont turm over
scanned it is pops the codes p0222 p0123-tps
so take apart the trottle body give it a little clean-put it back on- now it almost turned over- but didnt- check it and its is not setting it self when turn key so ---
got get anouther throttle body- put it on - still just cranks wont turn over.
a little extra??
do these cars have an imobilized- i just bought the car i got only 1 key and its not working(the fob) changed the battery still wont work-- merh
tried the reset for the ecm and tried a trick some one posted about syncing the potentiometer? nothing still
HELP ME PLEASE!!
a little extra??
HELP ME PLEASE!!
p-code
FWIW: from the MiniCooper Diagnosis without Guesswork manual:
P-code: P0123
Description: Accelerator pedal position (PWG)sensor A circuit high
Threshold value: >4.9 volts
Related component: Accelerator pedal position sensor
P-code: P0222
Description: TPS B circuit low
Threshold value: <0.09 volts
Related component: Electronic throttle position actuator (EDR) feedback.
Based on the two P-codes and the description, it sounds like a problem with either the accelerator actuator or the sensor...
Hope this helps....
P-code: P0123
P-code: P0222
Hope this helps....
Ok so the codes no longer come up no check engine light nothing.
Since I am not getting spark we replaced the ignition coil which has not fixed anything. I'm totally regretting buying this car :( still nothing
The intermittent ground signal to the coil is apparently non exhistnt but I have positive . I've talked to a few BMW techs. Who also thought the coil was the issue:(
So still just cranks .... Anyone know anything about where I can download a mini service manual?
Mini'mon
Aug 16, 2015 04:15 PM
