02 mini thinks key still in ignition
Old Nov 7, 2011 | 03:59 PM
abbynormal10's Avatar
abbynormal10
ok so my problem is that I think my 02 mini still thinks the key is in the iginition when I take it out coz it is dinging like it is. this causes me to be unable to lock the car with the remote. It takes about 4 times turning the key manually in door to lock it. anyone have any ideas?
Old Nov 7, 2011 | 07:50 PM
Ar50's Avatar
Ar50
I would start with the electrical side of switch, the black box behind the ignition switch in the column.
Old Nov 7, 2011 | 08:57 PM
abjb's Avatar
abjb
Greetings and welcome
I’m new to the mini world but generally speaking ignition switch problems can be a real pain and often require a professional.
If your electrical system isn’t shutting down (and it’s probably not) one morning you may get up to a dead battery.
Good luck
ab
Old Nov 10, 2011 | 11:46 AM
TTCummins's Avatar
TTCummins
Instead of taking the alarmist stand point as the above posters, I'd suggest attempting to lube the tumbler portion of the ignition.
This happened on another BMW I had, I think my E34.... anyway, the feature that detects key in had gotten worn from being used 500,000 times and was starting to bind. I shot some graphite in there, you can pick it up from a hardware store typically in the lock section it works great now. Puff some of the graphite in there, then work the key in and out 40-50 times, and cycle the ignition on and off a few to work it in.
If it is a matter of mechanical binding due to wear, this will rectify the problem.
Old Nov 13, 2012 | 05:59 PM
tranman8705's Avatar
tranman8705
I'm having the exact same problem on my 03 r53. Please let me know if you figure it out. Thanks!
Old Oct 24, 2013 | 05:36 PM
movieman's Avatar
movieman
Did anyone find a solution to this problem?
Old Nov 4, 2015 | 05:26 PM
Faerstorm's Avatar
Faerstorm
WD-40 works like a champ
I have a 2005 Mini Cooper S (R53) which thought it's key was in the ignition. As mentioned in prior posts, the risk of battery running out is exactly what happened to me. While I was ready to repair/replace the ignition switch, I went with WD40 (vs. Graphite) given that WD40 has some ability to not just lubricate but also dissolve some of the gunk which might be in there. Just a quick spray, worked the key on and off about 5-6 times. Hooked my mini up to a 6-amp charger and was able to immediately see it was repaired.
Hope that helps anyone else who Googles this question as I did, since lubrication is likely enough for the first-time fix.
09R56
Nov 16, 2022 10:49 AM
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
OutMotoring
Aug 6, 2015 09:32 AM
