P2096 Mark of the beast
Old Jul 5, 2011 | 08:59 PM
Silkworm's Avatar
Silkworm
For those fighting this as well:
Well been fighting this one for a bit now diagnostic software indicates a short on the secondary o2 sensor. My Plx devices odb2 monitor doohick shown -6% on the Long term fuel and after cleaning the map sensors and finding a leak at a intercooler boot (repaired) it has gone to -7%.
Also my coolant used to sit pretty at 194 but is now creeping as high as 205 on the highway.
The shop I go to tried to reset adaptations but it wouldnt let them they are thinking i need a new DME. Anyone else run into this?
I now have both o2 sensors brand new and even swapped to ensure they werent a bad set brand new.
also on fuel trims the long term when I read -7% is that telling me it is removing 7% of the normal fuel consumption? I think im running a little lean from this hence the coolant temp change but if i fixed the leak and it even drives better now shouldnt it be moving away from the extreme? I guess im looking for a better understanding of what I should consider ballpark of what it should read.
note I also have jcw injectors but they are tuned by RMW and been this way for well over 100k
Old Jul 6, 2011 | 09:23 PM
Some Guy's Avatar
Some Guy
If you can find a fix to this then I applaud you. I gave up after the fifth fix was thrown at it.
-reset adaptions
-update software
-replace green gasket at SC (vac leak)
-Replace bypass valve (vac leak INTO the valve, not through the valve)
-Replace IC boots (didnt even bother, another vac leak)
Fordgt4
Oct 10, 2015 10:42 AM
mk1leg
Classic Mini Talk
Oct 2, 2015 11:35 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
debitsandcredits
Sep 21, 2015 08:34 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
