Timing chain failure
Old Mar 18, 2011 | 08:07 AM
  #26
Stealth 993's Avatar
Stealth 993
Originally Posted by jrcsh6
dealer said it sounded bad, then called and said they added some oil and it's fine now. that doesn't exactly make sense, to me at least
It makes total sense. The timing chain tensioner works on oil pressure. If there isn't enough oil, it will start to make noise. We should all be in the habit of checking the oil at least once a month.
Old Mar 18, 2011 | 09:44 AM
  #27
MattSaint's Avatar
MattSaint
Because of my long commute, I check it every fill up, which equates to once a week. I too am not a hundred percent sure what a healthy Mini sounds like and I would rather not take the chance.
Old Mar 18, 2011 | 10:06 AM
  #28
MINIdave's Avatar
MINIdave
You were probably hearing lifter noise, not chain tensioner noise.
One more time folks.....the tensioner noise is not a ticking noise. When the tensioner is not presurized fully, it allows the chain to drag along the inside of the case, which makes a chain dragging sound, not a tick! It sounds exactly like you would imagine a chain rubbing the inside of an aluminum case, and it follows engine RPM, so the sound is both louder and higher pitched as the RPMs go up. It's heard mostly on cold engine start up, when the tensioer oil pressure has bled off and the chain is therefore looser than normal. Also, it will most probably stop suddenly as soon as the revs go up and the oil pressure increases.....
By all means run by your dealer and let them listen to your engine if you have concerns, but be aware that this engine does make a ticking noise, most easily heard at idle, and with the hood up - that's normal injector noise for this car, assuming your oil level is good of course. Low oil will make all sorts of ticking and clattering and even knocking noises if it's low enough. Check your oil frequently till you establish a usage pattern.
And just FYI, my 30K Clubman S uses no oil between my twice yearly/7,500 miles changes.
Old Mar 18, 2011 | 11:20 AM
  #29
timfitz63's Avatar
timfitz63
Eh, disregard this post... I didn't page over to see that about half-a-dozen other folks had already said the same thing... My bad...
Old Mar 18, 2011 | 12:12 PM
  #30
JimRoberts12's Avatar
JimRoberts12
ah very good then. maybe i missed something but i didn't see that as a cause anywhere when reading this stuff.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
makg
Aug 21, 2015 02:49 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
