SES Light - EVAP problem
Old Nov 22, 2010 | 02:52 PM
scarlettbueller's Avatar
scarlettbueller
Dear all,
I recently bought my 06 MCS from a local Ford dealer, then made the mistake of starting the car and letting it idle for quite a while as a friend was looking at it, the SES light came on, but then cleared after 5/6 starts.
The Ford dealer pulled the code and is reporting an EVAP issue, and will need to ship it over to a Mini dealer which could take a few days. Is this an issue for me to really worry about at all or should I tell him nto not worry about it (its going to be on their nickel), ie. as it cleared was this just a one time thing through my own mistake of letting the engine idle ?
Andrew
Old Nov 22, 2010 | 03:07 PM
ericfreeman's Avatar
ericfreeman
Make sure your gas cap if fully tightened. A loose cap will throw a code.
Eric
Old Nov 22, 2010 | 03:26 PM
ZippyNH's Avatar
ZippyNH
If it is on their dime...let them track it down...it is possible the car had a loose gas cap, or a cracked vacuum line, or a bad sensor....all stuff that if it worsens out of warranty, will light the light, and drive most folks nuts...and cause a fail on inspections if your community does them, and make the car harder to sell....so if they want to let a dealer look at it...and the dealer finds nothing...then at least the issue is documented...and it will make it easier in the future perhaps.
Letting a car idle for a long period should not cause the light to come on.so you did not "make a mistake"....so unless the gas cap was taken off/left off/was loose when you were letting it idle, get it checked.
Old Nov 22, 2010 | 03:28 PM
scarlettbueller
Thanks guys
Powershift
Aug 16, 2015 05:14 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
oldkid6
Aug 11, 2015 08:13 PM
pocketmaster
Aug 6, 2015 01:41 PM
