p1688 code on 02 r53
Old Oct 28, 2010 | 05:25 PM
unkn0wn1's Avatar
unkn0wn1
i have gotten a code of p1688 can anyone help me with this problem
Old Oct 28, 2010 | 09:36 PM
AK.JCW's Avatar
AK.JCW
Do you have any symptoms other than the code?
That is usually a bad/faulty throttle body valve, but without more infomation, that's about all I can give you
Old Oct 28, 2010 | 09:53 PM
AK.JCW's Avatar
AK.JCW
Old Mar 18, 2016 | 11:38 PM
Mod-Mini's Avatar
Mod-Mini
It could be a torn crank pulley, bad TMAP sensor, intake leak after the supercharger or bad bypass valve.
Old Mar 24, 2016 | 07:56 AM
+1 linked above on the bypass valve.
Old Mar 30, 2016 | 02:15 PM
ti22fjc's Avatar
ti22fjc
I had this code when I initially had my mini. Took a bit to pop up, and dealer ended up replacing the throttle body.
I had bought my mini from a Toyota dealership, and it came on when I was driving it home. Since it was so early, (even with 100K), Toyota paid for the fix at the MINI dealership.
Old Mar 31, 2016 | 12:59 PM
Unbreakable Lump's Avatar
Unbreakable Lump
This came up on my vehicle a few days ago as a pending fault. The generic MINI code description is "boost leak after supercharger." Turns out it was the plastic vacuum line with rubber tip that slipped off the nipple at the far left end (when facing the engine) of the intake manifold. This is the line that connects to the fuel pressure regulator on the other end. Plugged it back in, cleared the code and it hasn't come back.
maniacalmorgan
38
Sep 29, 2015 04:56 AM
jst_bc
Sep 11, 2015 07:45 AM
Zettinger
Aug 25, 2015 04:04 PM
one73ronin
Aug 19, 2015 12:36 PM
pewx3
Aug 7, 2015 03:34 PM
