My 06 MINI is sick :( Need good MINI mechanic in Northern VA
Old Oct 25, 2010 | 07:37 AM
Kinickie's Avatar
Kinickie
My 06 JCW has been mysteriously leaking coolant and oil. After being unable to locate the sources, I finally broke down and took it to the dealer (MINI of Sterling) for a diagnosis.
Turns out I have a coolant leak from the thermostat, so I need a new gasket and thermostat installed. I'm also leaking oil from the crank sensor, so I need a new O ring there.
And as a special bonus my lower control arm bushings are apparently torn, so they need to be replaced as well.
All told, the dealer wants about $1500 for the repairs. Maybe it's just me, but I feel like this is high. Does anyone know of a good MINI mechanic in the Northern VA area who might be able to do this for a more reasonable price?
Old Oct 25, 2010 | 07:52 AM
bahawton's Avatar
bahawton
Mine started leaking @ 14K miles so the dealer replaced the thermostat housing with an updated version.
I'm surprised they don't send out a recall notice because their TSB documents the problem...
Old Oct 25, 2010 | 08:07 AM
Kinickie's Avatar
Kinickie
Yeah that would be nice...
I found a recommendation over a DC Metro MINIs for Mach V Motorsports in Sterling and gave them a call. They want about half what the dealer quoted for the repairs If anyone here has had dealings with them I'd love to know how it went.
Old Oct 25, 2010 | 09:31 AM
MOMINIDC's Avatar
MOMINIDC
I think Mach V does good work. I've only been there for a rear sway bar but I know they've done a lot of good work for other MINI owners and they know a lot about MINIs. I'm sure DCMM folks will be happy to comment about their experience.
I had MINI of Sterling repair a leaking crank sensor seal, which was $2 for the O-ring but $207 in labor because they have to take the front end of the car apart. MoS does give you a 20% discount (see website for coupons) if you spend more than $1000 in repairs, but their prices are still high compared with an indy shop like Mach V.
Good luck.
Old Oct 25, 2010 | 09:51 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you need control arm bushings go with the Powerflex they will last alot longer.
The crank sensor oring is a pretty common leak.
Old Oct 26, 2010 | 01:17 PM
Kinickie's Avatar
Kinickie
Thanks for all of the helpful input. I've got an appointment with Mach V this Thursday for all of the repairs.
I read a few of the bushing threads here and am definitely going with Powerflex.
SosoMINI
Nov 22, 2015 03:17 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
MIminiclubman
Aug 5, 2015 09:14 PM
sungjk
Aug 5, 2015 08:23 PM
