Compression Test Results
Old Oct 14, 2010 | 12:49 PM
jimz68's Avatar
jimz68
Turned over 209,000 miles last week on my 04MCS, and decided to do a compression test.
#1 143 Lbs
#2 140 Lbs
#3 133 Lbs
#4 143 Lbs
Bentley manual shows a range of 131Lbs to 196 Lbs.
Soooo.....time to ponder the options.
Oh! Still on the original supercharger,too! Have had a 15% pulley on for about 185,000.
Jim
Old Oct 14, 2010 | 02:00 PM
ED955S's Avatar
ED955S
Nice!
209K miles in 6 years without major issues is a good one but wear and tear on the rings is now showing per your compression numbers. Mine is also an 04 but only 21K and just recently took dry compressions at 176, 175, 170, 173. My car is low mileage but I drive hard and spirited when road is safe.
Yea, it's time to rebuild yours before damage is done. ABF? Endyn?
BTW, how often did you change your oil and what type/brand because there is probably a lesson to learn from your good experience.
Tks. for sharing.
Old Oct 14, 2010 | 02:17 PM
muzak's Avatar
muzak
Did you ever service the SC at all? If not, that's promising.
Old Oct 14, 2010 | 04:37 PM
martinb's Avatar
martinb
Yes, what kind of oil? Synthetic? What brand?
Old Oct 15, 2010 | 07:02 AM
jimz68's Avatar
jimz68
I've been using Redline or Royal Purple, and NAPA (Wix) filters.
Usually change oil at 7500-8000.
Never serviced the supercharger.
Jim
Old Oct 15, 2010 | 12:24 PM
cmt52663's Avatar
cmt52663
#1 143 Lbs
#2 140 Lbs
#3 133 Lbs
#4 143 Lbs
Jim
my '04 MCS at 60k miles
150, 145, 145, 145
same car at 128k miles
160, 130, 130, 160 - from Turner Motorsport
165, 158, 158, 170 - from Mini of Peabody
note that the two measurements at 128k were taken on adjacent weeks, so the very different numbers should tell you something about the variances in approach and tools that can accompany compression testing, even by qualified technicians
the rest of the story can be found at the thread "Resetting the odometer the hard way", but the punch line is that I put in a crate works motor and new supercharger at 130k miles.
Filmy
15
Jun 6, 2023 06:27 AM
cinq
GP Talk
Sep 14, 2015 05:32 AM
Suspension Products
Sep 10, 2015 11:46 AM
Sep 3, 2015 02:06 PM
