2007 MC Whine When In Gear
Old Aug 30, 2010 | 06:24 PM
StLBrian's Avatar
StLBrian
I have a 2007 Mini Cooper with a manual transmission and approximately 45,000 miles. I started noticing a high pitched whining noise when the car is in gear. The noise goes away when I drop it into neutral. Has anyone experienced anything like this before or have any idea what the problem is?
Old Aug 30, 2010 | 06:42 PM
aklucsarits's Avatar
aklucsarits
Is the noise while under throttle? Under engine braking? Both?
Old Aug 31, 2010 | 04:28 AM
StLBrian's Avatar
StLBrian
It's both - Pretty much whenever I'm in gear there is the whine but when I put it in neutral the noise goes away. Oddly enough, however, it seems to start after the engine is warm (It takes a minute or so of driving before the noise begins) Not sure if it has anything to do with it but I live in College Station Tx where it's been 100+.
Old Aug 31, 2010 | 04:54 AM
moondawg14's Avatar
moondawg14
sounds like a noisy throw-out bearing. Does it go away if you push the clutch just a little bit?
Old Aug 31, 2010 | 06:48 AM
Bigprfed22's Avatar
Bigprfed22
If its specific to 2nd gear could be a trans bearing. Take note whether the whine is speed variant or engine speed variant, if you hear it more on accel than decel. So if you speed up it has a higher pitch or the whine stays consistent?
Old Aug 31, 2010 | 07:54 AM
aklucsarits
If it were a bad throwout bearing, I would expect the noise to only be prevalent when the clutch pedal is depressed.
Old Aug 31, 2010 | 08:14 AM
Bigprfed22's Avatar
Bigprfed22
+1
wildwestrider
Dec 27, 2015 08:20 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Sep 3, 2015 03:01 PM
Sep 3, 2015 02:06 PM
