Clicking Sound With CEL CC ID 029
Old Apr 24, 2010 | 02:02 AM
Thirsty Fire's Avatar
Thirsty Fire
Mini r56 S 2007 a clicking sound under the hood with cel the dealer claiming that Alta air intake is causing a misfire but I'm suspecting the high pressure fuel pump.
What do you think
Old Apr 24, 2010 | 06:25 AM
slinger688's Avatar
slinger688
What do you think
The only thing I can really suggest is to remove the Alta part and put back the OEM to see if the problem is still there.
Old Apr 24, 2010 | 06:43 AM
Thirsty Fire
But the noise is coming from the engine itself not the turbo and correct me if am wrong what an AIT do with misfire or HPFP it only more air into the engine?
Old Apr 24, 2010 | 06:52 AM
slinger688's Avatar
slinger688
With your description, it is difficult for anyone to give you a reasonable diagnosis.
There is always lots of clicking sounds from the engine which is normal. You will hear a lot more with the open CAI.
If you like the dealer to help you diagnosis this, then remove the parts they blame.
If you are a "normal" home mechanic, it would be relatively difficult to change the HPFP yourself. And it is expensive.
Old Apr 28, 2010 | 05:17 AM
Thirsty Fire
Ok here is an update
I took the car from the dealer they told me they don't know whats the problem.
Anyway, I checked the car today morning it had several fault codes
3 misfire
4 misfire
knock sensor
in addition to Cel with code CC ID 029
they have tried the HPFP, sparks, Coils, wires and injector but the problem still there.
Ok it's misfiring like crazy with a noise like clicking while driving only & when the engine get hot which I think it caused by the timing between the fuel and air and the spark in piston 3 & 4.
Is it the O2 sensor or what?
This thing is driving me crazy!!!
Old Feb 15, 2012 | 02:16 PM
themarques's Avatar
themarques
I would love to hear what the solution to this problem ended up being I am having the exact same problem as we speak and the nearest dealer is 700KM away..
Old Apr 16, 2012 | 01:02 PM
MNMLST's Avatar
MNMLST
Same here. What ended up happening?
David.R53
Sep 1, 2015 06:49 PM
makg
Aug 21, 2015 02:49 AM
Aug 19, 2015 12:51 PM
damncajun
Aug 17, 2015 08:25 PM
Aug 12, 2015 01:24 PM
