Help! My car's DEAD! :(
I saw my alternator once. I hope I don't have to get that far into tearing down my MINI again real soon. I had it out while replacing the supercharger. If I had the extra cash at the time, I'd have replaced that alternator just because of where it's placed. I'm not sure it could be pulled out to the passenger side through the wheel well or not.
Glad someone got you fixed up. While a working MINI is more fun than the typical vehicle, it seems to be twice the pain (or cost) when it's broken.
place volt meter across battery determine volts; start car , place volt meter across battery . volts with car running should be aprox. 2vdc higher . if not check for loose belt /bad altenator . what regulates the voltage to components on thes cars?
I'm guessing here.... most modern car alternators have built-in voltage regulator.
5 minutes is a bit of an exaggeration. How about remove the bumper cover, release the lamp connectors, remove the aluminum bumper, swing out the A/C coil, break loose the top radiator hose, pull a few wheel well nuts, remove the inner panel and swing out the radiator. Unless you've successfully reach it up through the bottom which may be possible or stood there holding all those parts in the air. Assuming all the necessary tools were in reach, I'd give it a half hour or more. JMO
btw, one of our club members is having issues with alternators locking up after warming up. One original, one new out of the box. Anyone heard of that before?
My battery was being drained by a bad power steering pump. If you are having trouble with the power steering it may need to be rebuilt. You can check to see if the power steering pump motor remains on by putting the car on ramps and going underneath to hear the power steering pump. I also replaced the power steering fan to be on the safe side. Some how the power steering pump and battery are linked. I had the power steering pump rebuilt at http://www.bba-reman.com/uk/index.aspx for $200 and the car is working fine. It's been about a week.
minipopkart
Aug 13, 2015 05:22 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
