Torque values
Old Jun 6, 2009 | 09:02 AM
starionturbo's Avatar
starionturbo
Torque values
Engine Block
Main bearing bolts, inner
M10 .................................................. .................................................. 60 Nm
Note: Replace, wash and oil screws.
Main bearing bolts, outer
M8 .................................................. .................................................. . 35 Nm
Coolant plug to crankcase .................................................. ............................ 23 Nm
Cylinder head and cylinder head cover
Cylinder head cover to cylinder head .................................................. ...................... 12 Nm
Thermostat to cylinder head
M6 .................................................. .................................................. . 12 Nm
Cylinder head bolts to crankcase
Jointing torque .................................................. ...................................... 40 Nm
Torque angle .................................................. ......................................... 90°
M8 .................................................. .................................................. . 28 Nm
Camshaft gear to camshaft
M12 .................................................. .................................................. 102 Nm
Seal plug, chain tensioner .................................................. ........................... 63 Nm
Seal plug to cylinder head .................................................. ........................... 18 Nm
Intake manifold to cylinder head
M8 .................................................. .................................................. . 26 Nm
Engine carrier to cylinder block .................................................. ..................... 100 Nm
Hydro-mount to body (screw)
M10 x 110
Jointing torque .................................................. ...................................... 56 Nm
Hydraulic-mount to body .................................................. .............................. 100 Nm
Guide and tensioning rail to cylinder head
Engine mounting to engine mount .................................................. ........................... 68 Nm
Upper stabilizer bracket to body mounting .................................................. ................. 100 Nm
Upper stabilizer bracket to engine mounting .................................................. ............... 100 Nm
Lower stabilizer to oil sump holder .................................................. ....................... 100 Nm
Lower stabilizer to front axle .................................................. ............................ 100 Nm
Engine vent valve to cylinder head cover .................................................. .................. 7 Nm
Stabilizer bracket to oil sump .................................................. ............................ 45 Nm
Mounting screws for mounting (Left) of intercooler to intake manifold
M6 .................................................. .................................................. . 9 Nm
Mounting screws for mounting (Right) of intercooler to intake manifold
Oil Pan
Oil drain plug to oil sump
M14 x 16 .................................................. ............................................. 25 Nm
Oil sump to bearing support
M8 .................................................. .................................................. . 31 Nm
Oil strainer to bearing bracket
Oil sump to crankcase
Oil sump to crankcase, Transmission side
Oil sump to crankcase, exhaust side
Case Covers
Timing case cover to crankcase cover
Deflection cover to timing case cover
M8 .................................................. .................................................. . 45 Nm
Timing case cover to crankcase (oval head)
M8 .................................................. .................................................. . 18 Nm
Crankshaft
Increment wheel on crankshaft
Flywheel
Dual-mas flywheel to crankshaft
M10 .................................................. .................................................. 90 Nm
Camshaft
Sprocket to camshaft
M12 .................................................. .................................................. 100 Nm
Note: Replace screws
Guide rail to cylinder head
M8 .................................................. .................................................. . 30 Nm
Tensioning rail to cylinder head
Seal plug (chain tensioner piston) to cylinder head .................................................. ....... 65 Nm
Vibration Damper
Vibration Damper to crankshaft
M12 .................................................. .................................................. 115 Nm
Note: Replace screws.
Connecting Rods and Bearings
Connecting rod bolts
M8
Jointing Torque .................................................. ...................................... 20 Nm
Torque Angle .................................................. ......................................... 90°
Note: Replace Screws.
Ribbed V-Belt with Tension and Guide Element
Belt tensioner to crankcase
M6 .................................................. .................................................. ...... 9Nm
M10 .................................................. .................................................. ..... 45 Nm
Belt tensioner to compressor
Tension pulley to oil sump
Camshaft
M12 .................................................. .................................................. ..... 100 Nm
M8 .................................................. .................................................. ...... 30 Nm
Seal plug (chain tensioner piston) to cylinder head ........................................... 65 Nm
Rocker Arms/drag Arms and Bearings
Rocker arm shaft to bearing cap
Oil Pump with Suction Element and Drive
Oil Pump cover to timing case cover inner
M8 .................................................. .................................................. ....... 18 Nm
Oil Filter and Pipes
Oil Pressure switch to oil filter
3/8 .................................................. .................................................. ........ 20 Nm
Oil filter cover to oil filter
3 1/4" .................................................. .................................................. ... 25 Nm
Oil filter to crankcase
M8 .................................................. .................................................. ......... 25 Nm
Oil Filling
Oil dipstick to crankcase
M10 .................................................. .................................................. ........ 50 Nm
M8 .................................................. .................................................. .......... 25 Nm
Water Pump and Drive
Water pump to compressor
M8 .................................................. .................................................. ........... 25 Nm
Water pump elbow to crankcase
M6 .................................................. .................................................. ........... 8 Nm
Thermostat and Connections
Coolant line to cylinder head
M6 .................................................. .................................................. ........... 12 Nm
Intake Manifold
Bypass valve to intake manifold
M6 .................................................. .................................................. ............ 8 Nm
M8 .................................................. .................................................. ............. 25 Nm
Bypass valve to intercooler
M6 .................................................. .................................................. ............. 8 Nm
Exhaust Manifold
Heat shield to cylinder head bolt torque
M8 x 20 .................................................. .................................................. ......... 13 Nm
Manifold bolt torque
M8 x 30 .................................................. .................................................. .......... 24 Nm
Emissions - control, Lambda oxygen sensor
Oxygen control sensor, Oxygen monitor sensor
M18 x 1.5 .................................................. .................................................. ........ 39 Nm
Oxygen sensor bracket to cylinder head
M8 .................................................. .................................................. ................. 10 Nm
Coolant
Heater bleed screw .................................................. ............................................... 4,5/6.5 Nm
Expansion tank retaining nut
M6 .................................................. .................................................. ................... 5 Nm
Radiator and Mounting Parts
Fan blade to motor retaining nut .................................................. .............................. 6 Nm
Motor to housing retaining bolts .................................................. ............................... 5 Nm
Oil Cooler - Automatic Transmission
Oil cooler to radiator .................................................. ............................................... 4 Nm
Exhaust Assembly
Clamp for final muffler
M8 .................................................. .................................................. ....................... 15 Nm
Exhaust system to exhaust manifold
M10 .................................................. .................................................. ..................... 60 Nm
Note: Replace nuts, coat threads with cooper paste.
Reinforcing panel to body .................................................. ........................................... 14 Nm
Exhaust mounting brackets to body .................................................. ................................. 14 Nm
Cover/rear muffler .................................................. .................................................. ..... 2.5 Nm
Old Jun 6, 2009 | 09:11 AM
starionturbo
Sorry wrong place.
Can someone move this to 1. Generation for me please
MGBill1186
Oct 2, 2015 06:54 AM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
pkillur
Sep 30, 2015 10:51 AM
Nicefeet
Sep 27, 2015 11:14 AM
