Mushroom fix updates?
Old Apr 24, 2009 | 05:36 AM
  #26
DaveTinNY's Avatar
DaveTinNY
I ordered my M7s directly from M7tuning.com and I think that was a mistake as far as delivery speed... It took over a month to get them. I suggest you check stock locally before ordering directly from M7. They were very courteous so I have no other complaints... it's just that I had to wait for the plates to be manufactured! After I placed the order I heard that my local MINI dealer had them in stock! Being an honorable person I stuck it out and waited for M7 (and kept my fingers crossed that my towers wouldn't mushroom). They didn't. Whew.
Old Apr 24, 2009 | 12:57 PM
  #27
ngweibing's Avatar
ngweibing
after u put the strut in, how tight should u tighted the nut ifi am using a torque wrench?
Old Apr 24, 2009 | 02:59 PM
  #28
beken's Avatar
beken
I was told 24 lb/ft or 33 nm
Old Apr 25, 2009 | 11:38 AM
  #29
DaveTinNY's Avatar
DaveTinNY
I torqued to 25 ft lbs.
Old Apr 26, 2009 | 04:59 PM
  #30
msjulie33's Avatar
msjulie33
Originally Posted by Soldo
Hey guys,
I know theres a ton of threads on strut tower mushrooming and i've read through a bunch of them and ...<snip>
You said you read a bunch so you may have read the thread my post(s) are in https://www.northamericanmotoring.co...8-post394.html
Basically I had read up on this before I even had my car so it's got M7 plates on top and Ireland fixed camber plates on the underside. I needed the negative camber boost and there's not a bend in sight on the towers.. car had about 24k now, and this recent winter was right up there in road pothole suckiness....
Enjoy
Old Apr 26, 2009 | 05:08 PM
  #31
ngweibing's Avatar
ngweibing
thxs for the tip
after i put it in... i cant seem to take it off... its very tight fitting..
Old Apr 26, 2009 | 05:57 PM
  #32
Soldo's Avatar
Soldo
Enjoy
Thanks for all the help from everyone. I ended up placing an order on the Madness plates because i too feel that they look a little better for the purpose of the plates since they have a bigger surface area than the Cravenspeed ones.
We'll see what happens. If I set the tourque to 25ft will that be enough to bend the strut towers back into place?!
Old Apr 27, 2009 | 06:01 AM
  #33
myles2go's Avatar
myles2go
I just ordered the Madness plates also!
I found a torque spec of 35 Nm which is equal to 26 ftlb. I got this from the JCW Strut Brace installation instructions. Should be good.
Old Apr 27, 2009 | 07:41 AM
  #34
Bigshot's Avatar
Bigshot
Originally Posted by hunter99
How well will these work with aftermarket camber plates. I have a set of the ireland engineering ones and would like to use both.
No need for them as the camber plates actually do the same thing only better!
Old Apr 27, 2009 | 06:41 PM
  #35
ve3hzz's Avatar
ve3hzz
Strut tower reinforcement plates/stress bar.
Today I went to Coopersport (they actually had a local shipping site) and got the m7 strut tower brace with the reinforcement plates. I looked at a FEW sites that carry different options. I looked at the m7 site and there dealers. The reinforcement plates alone were 140? ish..+ shipping + exchange + customs blah blah blah....end result is for the difference in price to the complete kit with stress bar was a NO brainer!!! Got the kit m7 makes locally today and at a GREAT price (sorry confidential).
Installed in the driveway today in about 20 minutes (cleaned tower where they mount from some rust proofing). After I took it for a test ride. It has made a difference and feels more taught in the front end and steering around large radius turns seems more stable. I know this as YESTERDAY (Sunday) was with the SOMC on the Rattler (little junior northern cousin of Dragon). Sandy roads, raining, lots of pot holes, frost bumps!!! and puddles. Car was OK but seemed somewhat loose during this event. This morning I noticed a slight off camber of one of my driver bolts (was exactly perpendicular prior). So I was concerned that it was time to do something now before it got worse, or required more drastic measures.
The reason I did not go with the under the tower reinforcement is simple law of physics. Some will argue this point, but basics hold true.
For every action there is an equel and opposite reaction. Now in this case there is also a force that if overcome will cause this effect we all know of.
The top plate help to aleviate that force. Now the under plate will distribute the force yes, but will not stop it. The top plate will help to reverse the forces. Not remove them, but help in fighting them. Add the stress bar to combat flexing in the top of the tower and it's a pretty stought piece.
Again not to argue with anyone here, just my .02 cents on this and what I have done.
I hope NO one ever has any mushrooming, but in the First Gen, without some assistance with the way our roads are I think eventually everyone will have this issue pop up (sorry no PUN intended).
Regards
Scott.
Old Apr 28, 2009 | 07:03 AM
  #36
Bigshot's Avatar
Bigshot
And another kool-aid drinker.........
Glad you like them.
Old Apr 28, 2009 | 07:50 AM
  #37
ve3hzz's Avatar
ve3hzz
Glad you like them.
Well since I was planning on putting in a stress bar, and for the price, it works well. ALSO since this bar can have the center section removed to do other work it also seemed like a decent design for that purpose instead of having to remove the entire bar if needed like most other stress bars I've seen and for less $$.
As far as your kool-aid reference, since you don't know me, I'll just chaulk that up to ignorance. Also it's in poor taste as I know to what you are referring.
Old Apr 28, 2009 | 07:55 AM
  #38
jimz68's Avatar
jimz68
Glad you like them.
It wasn't "Kool-Aid" it was "Flavor-Aid".
Grape, as I recall.........
Jim
Old Apr 28, 2009 | 08:41 AM
  #39
Bigshot's Avatar
Bigshot
LOL
many, many posts, threads, data shows that these strut bars do very little if anything to improve performance.
But like I said.....glad you like yours.
Old Apr 28, 2009 | 09:12 AM
  #40
myles2go's Avatar
myles2go
??? If your happy with your decision that’s great! The M7’s appear to offer enough additional strength to help with this problem and you got a strut brace out of it too. Excellent, I haven’t read of anyone having a problem after using them.
However your use of the laws of physics to say they are the better solution is faulty. A bottom mounted plate, such as those from madness, will reduce the psi by distributing the force across the entire top of the tower. With the top mounted plates, the contact area is just the top of the strut mount. Same force, smaller area.
Old Apr 28, 2009 | 12:19 PM
  #41
Cadenza's Avatar
Cadenza
I second myles2go on the physics of lower vs upper plates...
Lower plates absorb the impact more evenly while the screwed-on, top-mounted plates take most of the impact at the bolts/nuts and distribute it across the plate. From users' feedback, both designs work but one's got Bling and convenience while the other requires more elbow grease but costs less.
Me... I'm all about effectiveness and cost-efficiency.... CHEAP !!!
Old Apr 28, 2009 | 02:20 PM
  #42
ve3hzz's Avatar
ve3hzz
First, yes the forces on the bottom are distributed across the surface area. But the top mount is also exurting a force in the opposite direction to the upward force. As for more bling that was not the intention of this, it was to help solve/aleviate 2 things. 1 the potential for mushrooming on top plate of the strut tower, and 2 make the towers more rigid to help with flexing common in many vehicles today.
As for the more elbow grease, I for one am not afraid of doing things that way. In this case, cheap is not actually accurate. If I had removed my springs and put in the under plate as suggested, once I returned everything to the way it was, even IF I marked exactly where the bolts were, it would be potentially out of alignment. Then I would have to have it aligned in order to ensure what I just did, didn't make the problem (or potential) worse. Since I only removed 6 nuts, did not move the vehicle at all from level at rest, this potential is almost but eliminated. This is not to say that I would not have to have it done later, but that is when I do suspension work and replace my tires, which I plan to so some wear is not an issue now.
But I understand your point of view, just don't think it IS the cheaper way or better one. Best senario is to have both, and in future may make some plates to do this. Bolting a plate on top and bottom would be the best solution which I may do as time permits.
Regards
Scott.
Old Apr 28, 2009 | 02:50 PM
  #43
Cadenza's Avatar
Cadenza
There's no need to disassemble the strut assembly to install the under-tower plates. As for alignment, 1/8" raise in ride height is minor and probably doesn't require a new alignment (unless you're really picky about it). Undulations over the smoothest road surface will affect wheel camber in the same way.
Old Apr 28, 2009 | 03:16 PM
  #44
ve3hzz's Avatar
ve3hzz
Good to know.
Old Apr 29, 2009 | 07:08 AM
  #45
Bigshot's Avatar
Bigshot
And the towers of the MINI are so close to the firewall that the brace is not needed to prevent movement.
Old Apr 29, 2009 | 07:35 AM
  #46
ve3hzz's Avatar
ve3hzz
Oh ok if you say so.
Old Apr 29, 2009 | 10:15 AM
  #47
WJHMH's Avatar
WJHMH
HAPY HAPPY JOY JOY
My MM plates came in yesterday. Just need to get a break from the bad weather to install them.
Old Apr 29, 2009 | 10:44 AM
  #48
myles2go's Avatar
myles2go
Let me know how the install goes. I'm still waiting for mine to arrive.
Old Apr 29, 2009 | 11:27 AM
  #49
TJWoodson1's Avatar
TJWoodson1
What I did, not sure how correct this is, was jacked the car up and hit it. I took a block of wood and a rubber mallet and used the m7 SB plates as a guide. I got it tightened down and had it aligned, and it seems to be fixed...
Old Apr 29, 2009 | 03:04 PM
  #50
Bigshot's Avatar
Bigshot
......and it's not just me. Lots of racers say they don't do a thing for the MINI.
