Rear hatch hydraulic pistons dying?
Old Feb 4, 2009 | 03:55 PM
puckschmuck95's Avatar
puckschmuck95
The hydraulic pistons on my rear hatch (2005) seem to be "dying" as the hatch has trouble staying up and will close verrrrry easily.
Anyone else had this issue? Is there a maintenance fix or is "trash-and-replace" the fix?
Danke!
Old Feb 4, 2009 | 05:00 PM
Warped1966's Avatar
Warped1966
They wear out over time. They aren't hydraulic though. They are gas struts. They literally snap on and off. You should be able to replace them yourself and, since they are showing signs of weakening, I suggest replacing them before the you get a "boot to the head".
Old Mar 11, 2009 | 04:23 PM
puckschmuck95
I've been looking online for these with no luck and would hate to have to pay dealer prices.
Anyone got a 'hookup'?
Old Mar 11, 2009 | 05:36 PM
Warped1966's Avatar
Warped1966
Pop one off, get the part number and call an auto parts store. They can cross the part number over to aftermarket.
Old Mar 11, 2009 | 07:37 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Yeah, it would be a pretty generic part.
Old Mar 11, 2009 | 09:14 PM
1FSTMINI's Avatar
1FSTMINI
http://www.napaonline.com/MasterPage...port&VehCode=Y
Old Mar 12, 2009 | 01:05 AM
puckschmuck95
That's what I'm talkin' about!
Thanks 1st.
Old Mar 12, 2009 | 06:54 AM
buzzsaw's Avatar
buzzsaw
Danke!
Here's a source I found on our website that may be less expensive than the dealer
Old Mar 12, 2009 | 07:02 AM
1FSTMINI's Avatar
1FSTMINI
Thanks 1st.
no problem.
oem is $34.30 just to give you a reference. part #41626801258
Old Mar 20, 2009 | 12:08 PM
k-huevo's Avatar
k-huevo
Shipping and tax for one ATM 41626801258 was $31.42. It was so stiff I thought it was locked and defective. If two of these were installed they would probably open the hatch by themselves.
Old Mar 20, 2009 | 12:22 PM
ScottRiqui's Avatar
ScottRiqui
Hatch struts are one of those things where after you replace them, you'll wonder why you waited so long. I don't know how many times I got bonked in the head by the rear window on my truck's fiberglass bed shell before I finally spent the $40 and 20 minutes to replace both of the struts.
ClubmanS's Avatar
ClubmanS
Try realoem.com
I think they retail for $30 a piece.
Old Mar 20, 2009 | 12:23 PM
ClubmanS's Avatar
ClubmanS
The right barn door strut failed on my Clubman back in December. It was replaced under warranty.
The struts on my 2005 R53 have no signs of giving up yet (But when they do, they usually decide to fail when your head is underneath the hatch).
Old Mar 20, 2009 | 12:29 PM
xsmini's Avatar
xsmini
I've replaced mine a couple of times now. I've learned that you usually only need to replace one at a time, if you do both its hard to close the hatch....
Nik
Old Mar 20, 2009 | 01:18 PM
Warped1966's Avatar
Warped1966
You're lucky Scott, your truck's cap only bonked you. My truck, the infamous Battlestar Galactica, knocks my pucker string loose routinely and I still haven't replaced the damned things!
Old Mar 24, 2009 | 10:44 PM
puckschmuck95
Or $60 and 3 minutes in my case.
That was so bleepin' easy, I can't believe I put up with it for so long - probably the last 5 months.
Old Mar 24, 2009 | 11:08 PM
SlowGSX98's Avatar
SlowGSX98
Mine have been bad for the last 3 months and i've been to lazy to fix them. Princeton BMW wanted $45 a piece for the struts..
Old Mar 25, 2009 | 08:08 AM
JeffM's Avatar
JeffM
I replaced mine about a month ago. It's a piece of cake. I got an aftermarket set from autohausaz.com ($24 each). Good quality stuff - look the same as OEM, even same color writing and font on them, so I suspect they come from the same source as the BMW parts.
Old Mar 31, 2009 | 12:52 PM
gpugliese's Avatar
gpugliese
Bit of a redundant question, but is there a write up on how to replace the hatch struts somewhere? I have not secured a set of replacements yet so it may be obvious when I get my hands on them... do they just pop off?
Old Mar 31, 2009 | 01:28 PM
Warped1966's Avatar
Warped1966
They mount on a ball stud. If you look at the ends, there is a metal clip. Take a regular screwdriver and slide/work the clip towards the end of the fitting. You can just pry it out towards you too but if you do that hold your other hand over it because it takes off with every bit of the ferocity of a F/A-18 at full afterburner being launched from an aircraft carrier. Wear eye protection too...
Old Apr 2, 2009 | 10:31 AM
JeffM's Avatar
JeffM
Once you have the old struts off, the new ones just push right on - no tools needed. It really is as easy as it sounds - just a small screwdriver needed to remove the old struts. I also put a little dab of grease on the stud that the strut ends attach to, to keep them moving smoothly and prevent possible noise.
Old Apr 2, 2009 | 11:22 AM
MINIdave's Avatar
MINIdave
And lube your hinges while you're in there........
Old Apr 12, 2009 | 11:59 AM
gpugliese's Avatar
gpugliese
Well that was easy, I should have done that a long time ago (as mentioned earlier), LOL.
Old Oct 3, 2011 | 07:16 PM
WJHMH's Avatar
WJHMH
I've now run into this problem also on my R53, funny thing is I replaced the rear struts on a Ferrari 348 cheaper than some of the prices stated here ($15.00 per strut @ Pep Boys) Bosch or some other company has a part similar to what I'm looking for far less than any OEM MINI/BMW cost.
Old Mar 6, 2012 | 06:52 AM
kerver's Avatar
kerver
I ordered mine off ebay and just spend literally 2 minutes to change both of these out.
Great thread!
