ABS, TPM, AND DSC LIGHT!
Old Jan 3, 2009 | 05:22 PM
Phantom's Avatar
Phantom
ABS, TPM, AND DSC LIGHT SENSOR WIRE CHAFFING!
I am one of the many that have had the sensor or pulse gen fail and today I finally got to replace it. I was unsure what sensor was out I only had a front sensor to fiddle with so I started with the front left (drivers side) and well I put the new sensor in and nothing O/C/S (ops check same) SO I rotated my tires and cleaned my wheels both outside and inside and applyed wheel wax as I had them off already along with suffing up my brakepads to remove the glaze.
ANYWHO, I did the same to the front left and this is what I found:
The wire got "sucked" into the belts and was rubbing on a pully till well it chewed through might want to check yours out.
Old Jan 3, 2009 | 05:36 PM
Locust's Avatar
Locust
Wow, nice chew marks on yor sensor cable from the belt. How does the belt look on close-up inspection? Thanks for sharing your problem! I am outside iin my garage right now inspecting everything. Looks like everything checks out here, but good info just the same.
Old Jan 3, 2009 | 07:16 PM
Phantom's Avatar
Phantom
The Belt is perfect with the exception when it get humid here it sqeaks a tad... very annoyi but I learned to accept it.
Old Jan 4, 2009 | 05:30 AM
frenchie's Avatar
frenchie
Did you find that the cable was not routed correctly?
Does the cable have clips to secure it and prevent this from happening?
Old Jan 4, 2009 | 06:47 AM
03BRG's Avatar
03BRG
Good to see that you did not have to NRTS it!
Old Jan 4, 2009 | 12:33 PM
Phantom's Avatar
Phantom
rather NRTS it than PQDR it I F-in hate QDR's.... shivers
Old Jan 4, 2009 | 12:36 PM
Phantom's Avatar
Phantom
As far as I know it was in the place it was ment to be it just appered that some how the wire got pulled into the engine area, I dont know how all I know its it chaffed and cut the wires.
Dec 23, 2015 10:36 AM
Powershift
Aug 16, 2015 05:14 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
1964geo
Aug 10, 2015 06:22 AM
