OEM SC Bypass Valve Forensic Analysis (pics)
Old Nov 7, 2008 | 03:55 PM
SeanKidd's Avatar
SeanKidd
'03 MCS 60,000 Miles...Well, I went OEM replacement for my bypass valve, (drivability) Here is the stock 2003 MSC Bypass valve and its $0.20 failure. The first thing I did when I got my OEM valve from Classicmini (thanks Jayson) I held it up to the light, yup you could see a corona of daylight, of course I wanted to know how much it would leak by...(no you cant blow any air past it ) Replacement was relatively easy about 1.5 hours, very cautious about the plastic inlet tube tab. All my power was restored, after replacing the belt, IC bellows(Alta)plugs (Beru...Thanks Outmotoring)and wires (oh yes #3 Corrosion on coil, for another post), this spring caused all my woes. Hey MINUSA....This should be a TSB!!! I have NEVER seen a diaphragm spring break. (and my other car is a FIAT)
Attached Thumbnails OEM SC Bypass Valve Forensic Analysis (pics)-100_3719.jpg   OEM SC Bypass Valve Forensic Analysis (pics)-100_3722.jpg
Old Nov 8, 2008 | 09:29 AM
jhiggs26's Avatar
jhiggs26
Woh thanks for the photos SeanKidd! Glad your MCS is singing again!
Jeremy
Old Nov 8, 2008 | 09:48 AM
paul martin's Avatar
paul martin
just done mine she whines again wooohooo
Old Nov 8, 2008 | 11:15 AM
k_h_d's Avatar
k_h_d
How noticable were your power losses? I guess a boost gauge would show a drop and be good diagnostic value?
Old Nov 9, 2008 | 05:09 AM
paul martin
power loss was huge it was like i was driving my old cooper again ,sluggish pull away erratic power surges it was horrible ,and a very very quite supercharger , im pleased with upgraded version now i need a pulley reduction for more grunt
Old Nov 10, 2008 | 08:02 AM
SeanKidd's Avatar
SeanKidd
CS Bypass power loss
The spring failure caused the butterfly to close maybe 50%, but that does not mean half boost. Boost guage is next satisfy my paranoia, I hav NAV so Boost will need to go in the vent, but since Presure is inversely proportionate to temperature, there will be an error, maybe one of those scangauge displays is the answer.
Old Nov 10, 2008 | 12:32 PM
joey1320's Avatar
joey1320
i'll pass jayson the thanks. bet he'll be happy to know he was able to help
wkp1219
Nov 13, 2015 07:52 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
