Does your engine do this?
Old Sep 4, 2003 | 10:12 AM
TwOMINIs's Avatar
TwOMINIs
I've noted this for a while, but have recently become more aware of it. If I idle and then "punch it" there is a distinct "bog" as if the engine hesitates and it wants me to rev slower. This doesn't occur when the revs are already up.
Is it more noticable b/c I have a cold air intake? The car runs strong as ever, and I haven't noted a change in performance. It is of concern? Does your "S" do this?
His, Chile RED over, Madness intake, Magnaflow, Helix Pulley & RDR Swaybar
Hers, Electric Blue / Union Jack on top and BONE Stock
Old Sep 4, 2003 | 10:21 AM
Phobol's Avatar
Phobol
Does it sound like a champaign bottle uncorking? Not the pop but the air escaping sound... Or a vacuum cleaner when you pull the sucked in paper out? It's the air being sucked hard into the engine, you can hear it loud and clear with the intake.
Motor On!
Old Sep 4, 2003 | 10:24 AM
~Scooper~'s Avatar
~Scooper~
I think you're talking about the "stumble"...I have it, as do many others. Try a search on the word "stumble" on the site here, you'll probably find some useful info...
If you can provide more info on your MCS (build date, etc.), some of the more knowledgeable folks on here might be better able to help.
If it helps, there are a number of folks here who can empathize!
_________________
<IMG SRC="https://www.northamericanmotoring.co....jpg"> BLK MCS All 3 packages...I call him...Buster.
Old Sep 4, 2003 | 10:51 AM
TwOMINIs's Avatar
TwOMINIs
I'm don't think it's the dreaded stumble, unless I'm misunderstanding the stumble. It only happens only when the RPMs are at idle and then the throttle is punched fast and hard. When driving acceleration is smooth.(for the most part)
I don't think I can describe the sound.
It reminds me of my 2 stroke Suzuki '74 TS 100 I owened as a lad. From idle to full throttle there is a hesitation as if the motor is "choking" on too much fuel/air. There is a delay in the increase in RPMs, a "bog".
My "S" is an Aug 02 build.
Is there is anyone willing to start their "S", let it idle for a bit and then punch it fast and hard and see if there is a hesitation.
Additionally, I think I have recently developed the cold start issue as it starts and then dies on first start. Subsequent starts are smooth and brisk
Old Sep 4, 2003 | 11:06 AM
jstines's Avatar
jstines
The engine "bog" you describe is a known issue with the engine management. There are three issues related to the software:
1. Stumble/hiccup (momentary engine cutout in 1st gear launch)
2. Engine Bog (slow acceleration no matter how much throttle is applied, occurs infrequently and without warning)
3. Yo-yo acceleration (acceleration oscillates usually in the 3000-4000 rpm
Your situation sounds a little different, since you can cause the bog on-demand. Probably still related, though.
We're all waiting on a fix...and waiting...and waiting...and waiting...
See ya,
JS
Old Sep 4, 2003 | 06:23 PM
Nicky's Avatar
Nicky
Okay, I have all 3 issues with my S, is there anything that can be done about it?
>>See ya,
>>JS
Old Sep 4, 2003 | 06:29 PM
Tokio's Avatar
Tokio
>>>>See ya,
>>>>JS
Tell everyone you can that may be interested in buying a Mini about these problems. It's not right and BMW should not sell any car with these issues.
Old Sep 4, 2003 | 06:38 PM
jdw5155's Avatar
jdw5155
This might be too obvious so forgive me if you already ruled this out, but might you be triggering the ASC/DSC with a little wheel slippage? Try turning off your traction control and doing the same hard start, you should now lay a nice bit of runflat on the pavement rather than bog.
If that's not it I would then refer to the above posts.
Jim
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
