Oil drain plug stuck... help!!
Old Apr 14, 2008 | 10:18 AM
  #26
Gromit801's Avatar
Gromit801
And yet, the plug SHOULD be a 13mm head. There shouldn't be an SAE nut or bolt anywhere on a Mini.
Old Apr 14, 2008 | 10:20 AM
  #27
xsmini's Avatar
xsmini
On my 03 the original plug was 13mm, then they changed the size in the later years to 1/2". I think that is why I rounded mine the first time. Replaced the plug at the previous oil change and installed the new 1/2" and then (many miles/ months) later tried to remove w/ 13mm and rounded the corners..
Nik
Old Apr 14, 2008 | 10:30 AM
  #28
THE ITCH's Avatar
THE ITCH
1/2=.500 vs 13mm=.512
Originally Posted by Gromit801
In the world of tools, the one place where metric and SAE meet, is at 1/2 inch and 13mm. The two are close enough that it makes no difference really.
Old Apr 14, 2008 | 12:15 PM
  #29
Gromit801's Avatar
Gromit801
One thing that wouldn't surprise me, is if some 1/2" SAE plugs found their way onto a Mini after some Jiffy-Jock stripped the head off the original 13mm. When I worked for NAPA auto parts a wile back, places like that were our best customers for new drain plugs.
Old Apr 14, 2008 | 12:21 PM
  #30
xsmini's Avatar
xsmini
Naw I buy mine directly from Mini, the are now 1/2".
Nik
Old Apr 14, 2008 | 12:23 PM
  #31
Ric in Richmond's Avatar
Ric in Richmond
I haven't verified on the mini that you can suck the oil out...but that is how I have done all my BMW's.
I actually got more oil out that way. Not worried about any stuff settling to the bottom of the pan and "not being drained away"...since I don't think the draining process would flush anything sitting on the pan bottom anyways.
Of course it would still irk me that the bolt was stuck.
Old Apr 14, 2008 | 01:48 PM
  #32
sprp85's Avatar
sprp85
take it to a oil change shop, tell em that the bolt is stuck
i only paid $15 for new plug and pulling out the stripped joint.. + oil change with customer provided supplies.
Old Apr 14, 2008 | 06:29 PM
  #33
Ryephile's Avatar
Ryephile
The subframe bolts work better with 5/8" than they do with 16mm. Consider the MINI mostly Metric and part Imperial and you'll do fine.
Old Jan 19, 2010 | 04:25 PM
  #34
cobra94563's Avatar
cobra94563
Just reporting I had a severely tighten and then rounded oil drain plug.
The Irwin bolt grip sockets worked great. I did have to put a breaker bar and step on it from the drivers side wheel well. All is good again.
Old Jan 20, 2010 | 03:06 PM
  #35
rsvp9146's Avatar
rsvp9146
I'll add my 2 cents here.
I had this same problem on a Cooper S, oil drain bolt hit with impact gun, could not get it with an wrench, socket, or breaker bar. Breaker bar with 13mm socket ended up rounding the nut off. I then tried vice grips with a big pipe over one end, no luck.
I ended up filing down the edges of the nut until I could literally hammer a 12mm socket onto the bolt. I made sure it fit on there tight. One quick pull with the breaker bar loosened it up.
Sure enough, when I threaded in the new bolt in, it was an SAE 1/2". go figure.
Old Jan 20, 2010 | 03:34 PM
  #36
JAB 67's Avatar
JAB 67
Happened to me too. I made the dealer remove it at no charge since they had put it on too tight. I then replaced with a Fumoto.
Old Jan 21, 2010 | 09:22 AM
  #37
cobra94563's Avatar
cobra94563
Since this seems rather common, I'll also add - do not buy the oil plug at the dealer!
I saw it priced at 3.68 on realOEM, so I figured the dealer would charge ... maybe $6?. I go in and request it, purchase comes to $13! what a rip off!
Buy it online or at your local parts store.
Old Jan 21, 2010 | 10:37 AM
  #38
ZippyNH's Avatar
ZippyNH
I bought like 6 plugs for 4$ each.. Was maybe 3.50, from a vendor...mini oem. Still, I'll be installing the fumoto drain valve soon.
Don't laugh, I got the drain plugs so I could use a fresh on with each or everyother oil change and avoid the mess of roundindit off, or having the rubber gasket leak.
woodstudio
Mar 15, 2020 08:28 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
