Cold start chatter
Old Jan 28, 2008 | 03:01 PM
  #126
ehart13169's Avatar
ehart13169
Btw.....about 500 miles when I first heard it, about 12-13,000 miles when it went to the dealer with the noise returned.
Old Jan 28, 2008 | 03:11 PM
  #127
ehart13169's Avatar
ehart13169
Originally Posted by msh441
Saw this posted elsewhere. Thought it might interest a few here. I can't speak to the validity or authenticity of the UK PUMA... but here it is none the less:
Quote:
Originally Posted by brgc00perboy
Just back from Elms. Workshop Controller has said that the car was started in the presence of the PUMA rep.
SITUATION
Noise was reproduced.
PUMA attributed noise to crankcase vacuum pump.
There is a PUMA case number for this.
Replacement part will not fix the problem.
DETAIL
Noise caused by slack in journal between camshaft and vacuum pump. When under load (i.e. during the first minutes of running), the pump journals rattle. As the pressure in the crankcase equalizes, load is reduced on then pump and noise goes.
TEST
Remove vacuum pipe during first few minutes of running (get a friend to do this). Noise should go away.
FURTHER ACTION AND OPINION
Now this is what the guys said to me so I am going to try this at the weekend. My engine knowledge is a bit limited so opinions on this are welcome. I'm still not convinced about this and will now be pursing the matter with MINI customer service as Elm's Cambridge can do no more.
Any suggestions on the next step?
I'm assuming the vacuum pump he's referring to is at the back of the cylinder head (towards the driver's side of the car)....if so, that could be the issue. I have a mechanic's stethoscope (not sure about spelling there), and when my car was making the noise, it was loudest right there. Has anyone heard any updates regarding whether or not the above diagnosis was proven right or wrong?
Old Jan 28, 2008 | 05:10 PM
  #128
msh441's Avatar
msh441
Yeah... the owner that posted it on MINI 2 suggested he tried it himself...
...like everything else so far, it had absolutely zero effect and his engine still rattled away.
If this is a "normal" charactoristic for this car... it will be a "normal" charatoristic of someone else's car. I won't have it, personally.
Old Jan 28, 2008 | 08:09 PM
  #129
Event-Horizon's Avatar
Event-Horizon
How often do you get this noise? Is this really something that going to cause the hassle of selling your Mini or possibly losing money on it?
I've heard this noise all of two times over the past 3500 miles, for all of 30 seconds. I don't think this justifies getting rid of the car. Maybe if worse comes to worse, you can get a lemon law on your Mini.
Old Jan 28, 2008 | 10:42 PM
  #130
msh441's Avatar
msh441
Over 11,500 miles, it progressivly got worse... occurring more and more frequently... lasting longer and getting louder each time. Yes... somthing like 1-in-20 starts. But each of those could be clearly heard outside the vehicle gathering onlookers each and every time. Driving down the road it sounded as if it was going to fall apart or eat a valve. Bottom line: it's just not right for a $35000 car.
So yes, if MINI can't fix it for good (they get one more try if the engine replacement doesn't do it)... I will do my best to Lemon Law the car and let MINI buy it back. Better that, then keep the car and risk no one wanting it when I sell it or trade down the road. I mean, personally... if this issue isn't properly addressed by MINI, I don't think there will be many who would want to touch a used R55,R56 or R57S (considering all three engines are fundamentally the same).
"Normal" noise? Trait of the engine? No thanks.
Old Jan 29, 2008 | 02:22 PM
  #131
Auntluly's Avatar
Auntluly
I have it too. I'm just sick about this. I had to wait 2 years to order my "dream car" and my dream turned out to be a nightmare. "Lilluly" is at the dealers now. Its been there about 6 times for this. I have a couple of questions if anyone can help.
1. If it comes down to replacing the engine, won't I be getting the exact same engine?
2. My state says you have to use the lemon law before the car is 1 year old and the dealer has to have repaired the same problem at least 4 times. "Lilluly" will be 1 in 25 days and so far the dealer has only attempted to fix it once with a Non return oil valve. They said they couldnt duplicate the noise the other 5 times I took it in. I guess my question is.. will I not be able to lemon law it? Will a lawyer help? I appreciate any advice. Thanks!
(Thank You MSH441 for your great posts! I actually took a couple of them to my dealer this last time and asked him to please check out this forum.)
Old Jan 29, 2008 | 02:56 PM
  #132
OSUmcs's Avatar
OSUmcs
So I think we should tally this up so we can get a better idea of who, where, when and how.....does your car do this? Build date? And how often does it occur? Have you taken it to your dealer for this problem?
My car does it...Jan 31st 07 build date...about 2x/month...I took it to the dealer 6months ago...they couldnt replicate and knew nothing about it. Decided to hold off until more people came forward so they could find a solution. Coming up on one year of ownership.
Old Jan 29, 2008 | 03:50 PM
  #133
Sundevil's Avatar
Sundevil
I have that problem too! My car is only 4 months old. I brought it in to the dealer, but they could not replicate the problem. I emailed MINIUSA and they advised me to try another dealer!
Old Jan 29, 2008 | 05:29 PM
  #134
Event-Horizon
Ok, I think it’s a good idea to create a database of sorts about "cold start" noise. Maybe this way we can find a common link with the problem. Any other information that we should add?
Cooper S, 6-Speed Manual
Build Date: October 2007
Miles: 3500+
Duration: 30 seconds to 1 minute
RPM range: 1500-2000rpm
Ambient Temp: low 30's first time, 18 degrees second time.
Oil: Factory Fill, Castrol 5w-30, oil level full
Any other relevant information:
Car parked with the nose of the car in a downward slope both times. The sound can best be described as a growling, clattering, or rhythmic tapping. This cannot be piston slap at this speed because the frequency is too low. At 2000rpm, piston slap would would happen over 33 times a second. This is valve train related for sure due to the half-speed frequency of the sound. This means that at an engine speed of 2000rpm, the cams are spinning at 1000rpm or roughly 16 times a second.
Old Jan 29, 2008 | 08:45 PM
  #135
Impulsive's Avatar
Impulsive
Sorry, sincerely, to those of you dealing with this problem. It hurts me reading six pages of posts and I don't even own the car.
As 'msh441' just stated above, this is NOT acceptable for ANY car, let alone a $35k BMW. And to have this issue continue unsolved (publicly) is pathetic.
I REALLY wanted to buy the JCW 210hp version this summer/fall but there is no way I'm paying that kind of money to a supposed "luxury" automaker that can't build an engine that makes as little noise as a $15k Kia Rio.
Good luck to you all ... you don't deserve this, especially after spending that kind of money.
Old Jan 29, 2008 | 09:06 PM
  #136
rdwatt's Avatar
rdwatt
Miles: 3500+
MCS...right? How about auto or manuel?
Old Jan 30, 2008 | 06:32 AM
  #137
Bishamon's Avatar
Bishamon
Build Date: February 2007
Miles: 3000 kilometers
Duration: 30 seconds to 5 minutes
RPM range: 1500-2000rpm+
Ambient Temp: anywhere from +3.5 to -10.0 Celsius
Oil: Factory, oil level full
The car is always parked on a level surface, and there are no other apparent common factors. It can happen after sitting for only a few hours after a 20+ minute drive, and it may not happen after sitting for several days. The only common thread seems to be the cold temperatures.
Old Jan 30, 2008 | 06:38 AM
  #138
Gil-galad's Avatar
Gil-galad
Nearly 140 posts on this issue and counting, plus 500+ over on MINI2. IMHO, this thread is at the point of warranting sticky status.
Old Jan 30, 2008 | 06:58 PM
  #139
dneal's Avatar
dneal
1. Don't really understand what you mean by "exact" Same serial number? Maybe. Same type? Definitely. You could get a short block (the basic block, crank, rods and pistons) and they use your existing heads and other parts/accessories. They could also only replace a particular part on your current engine that they deem faulty. Finally, you could get a brand new, complete engine.
2. At this point, and if you think you want to pursue lemon law action, you should talk to a lawyer. Do you have the paperwork from the previous times you took the car in? Were they for the same complaint? I would think that the 4 previous times would count (if it was for the same complaint). They basically validated your complaint by replacing the valve.
Old Jan 30, 2008 | 08:36 PM
  #140
porkchop's Avatar
porkchop
Cooper S, Auto
Build Date: Aug 2007
Miles: 3000 mi
RPM range: 1000-4000rpm
Ambient Temp: 10-20F
Old Jan 31, 2008 | 12:28 AM
  #141
SPECKY's Avatar
SPECKY
Ok, Here goes. My MCS has this NASTY RATTLE, and i'm on Mini2 as Specky 1. Think mine was the first to have a new engine back in october last year. Before the new unit was fitted it had everything done to the old one and NOTHING fixes this problem. I've been given alsorts of excuses by my dealer but top and bottom of it is this
THEY "STILL" DONT KNOW AND I DONT THINK THEY REALLY CARE EITHER.
Personally i'm loosing faith now and feel like getting shut of it, but i've got far too much in mods on the car that cant be transfered to another mini.
I'm currently in contact with Mini UK about the whole disgusting situation because my new engine is just like a tractor and i ran it in to the letter as owners manual describes. I wanted so much to keep my mini this time for a few years but with only 21 months remaining on Warranty... this aint gonna happen.
Like others, i just cant believe that a company as big as BMW with a reputation for quality cars cannot or will not fix this issue once and for all.
Regards, SPECKY......have a nice day peeps.
Old Jan 31, 2008 | 12:33 AM
  #142
minicobra1's Avatar
minicobra1
Email www.motoringfile.com, I've tried to get them to post this issue up and look into it, but they have not responded. I think we need to bring this issue into the spotlight, the more people who are aware of this, the better chance Mini will make it a top priority to solve the problem. There is clearly a problem, it's by no means normal. I'm concerned that a lot of people will have engines that prematurely wear out or break down, probably just after the warranty expires. If it's an oil issue, then there is definitely premature wear happening.
Anyone here write a letter to Mini corporate? what was the response?
Old Jan 31, 2008 | 12:36 AM
  #143
SPECKY's Avatar
SPECKY
I've sent an e-mail neumerous times to Mini uk and got JACK back
Old Jan 31, 2008 | 12:52 AM
  #144
minicobra1's Avatar
minicobra1
That sucks
There has got to be some sort of corporate customer service or complaints dept that we could all send a letter too. Maybe get the name of the VP of consumer products or customer affairs, write him a letter and send a petition with everyones name on it who has experienced this problem.
Old Jan 31, 2008 | 05:06 AM
  #145
korby's Avatar
korby
Hey Specky I've been following your problems an mini2 for months welcome to NAM .
Old Jan 31, 2008 | 05:20 AM
  #146
SPECKY's Avatar
SPECKY
Yo korby, nice to be here. Like the site V much.
Yeah shame about mi probs cos mi mini is the dogs danglies. LOVE IT. Thing is, if i were to get shut of it, there's nowt out there that floats my boat apart from Range rover sport, mustang shelby and trucks. But Mini.Boo wont let me have any of em.
Old Jan 31, 2008 | 10:28 PM
  #147
msh441's Avatar
msh441
Greetings Specky! Welcome to NAM!!!
I would have to disagee that MINI doesn't care about diagnosing and fixing this issue. IMO, I think MINI are pooping their pants, as they seem to be truely stumped by this one. Some dealers however, do the one-start "we don't hear anything", evaluation. Add to that the communication between the dealers, regional techs (PUMA reps), MINIUSA and MINI doesn't seem to be flowing as efficiently as one might hope. It's a mess right now.
Like most here, I also believe the relationship between the cold-start programmin in the ECU, oil pump and specific oil used will be found to be the basis for this issue... but we'll see.
Like you, I'm getting a new engine this week and my old head & block are going back to MINI for evaluation. I'm aware (based on your, and other experiences on MINI2) that this is a temporary fix and will only serve to buy time until a permanant fix is found. The one thing that terrifies me is the statement from MINI passed on by a few owners that "its normal", "an acceptable trait of this engine" and "no damage is occurring" (despite a lack of lubrication in a running engine... yeah, right).
It's hard to stay positive and maintain faith in the car. I've been without mine for over a month now and probably won't have it back for a couple weeks. Add to the fact that once I get it back, it's only a matter of time before it begins all over again. If the dealer would buy it back for the cost of the car and the JCW kit, with the agreement that the money would go towards a new 135i... hmmm, hard choice... despite the fact that I waited three years for the MINI and had the idea of keeping it for the long-term.
I guess it's what I get for buying a 1st model-year car... but who are we fooling: there are no changes to the 2008 engine, so owners-to-be will likley be in the same boat sooner or later. Because of this I would think MINI wants to get this sorted quick!
Gabe is aware of the issue.
I'm assuming they haven't posted anything yet as I'm sure they 1) are waiting for some specific diagnosis (just like everyone else)... 2) are hoping for a fix, soon... and 3) don't want to create undue panic in owners who are not yet experiencing this issue. I mean, it's a rattly-sounding engine even when it's running right. You'll have everyone rusing in to the dealers whether they're experiencing this issue or not.
Old Feb 1, 2008 | 01:30 AM
  #148
SPECKY's Avatar
SPECKY
Hey, msh441 thanks for the welcome.
I agree with you i suppose. I'm just very very frustrated as, like you, i want to keep Sulley for quite some time. After 26 years of motoring and some 16 cars i just find it hard to believe that i've gone backwards as regards engine quality and reliability! God forbid what costs i would incur outside warranty with my mini if i kept it that long. All i really want is some fix, answers and reasurance from MINI that this Will be solved and i'll be happy!
But sadly I, you and what seems like hundreds of others now, are not getting this. Just off to fone Mini UK Customer services now, this is my daily ritual, followed by a supporting e-mail.
SPECKSTER
Old Feb 1, 2008 | 12:07 PM
  #149
johned206's Avatar
johned206
I have 20,000 miles on my 2007 MCS. I have experienced the rattle five times. I drive it every day. I have been unable to figure out any pattern that would connect with it's occurrence. Since November we have experienced many sub-zero days here in the mountains. In December I installed an oilpan heater and I hook it up every night. Yesterday I got the rattle. It wasn't any colder than it's been, my oil is topped up with the correct type and grade, I had driven the car the previous day, and it's parked on the level. I go in for my first service in 3000 miles and I'll discuss this with the service manager, although it doesn't look like much can be effectively done at this point. I live 200 miles from the dealer and I can't be dropping the car off every week for some experimental, predictably ineffective solution. My two cents.
Old Feb 1, 2008 | 12:40 PM
  #150
SPECKY's Avatar
SPECKY
OMG !!!! 200 miles from dealer !!!!!! Maybe they'll do home visits ??? LMAO
