about brakes
Old Dec 26, 2007 | 10:34 AM
mini22's Avatar
mini22
about brakes
Ok i bought some hawk brake pads and was going to put them on i noticed the rotors look worn out can the rotors be milled or do i have to replace those too if i have to replace how are they or will i be better of buying a bbk kit
Old Dec 26, 2007 | 10:39 AM
BWROOFCHEX's Avatar
BWROOFCHEX
definitely replace them !! The advantage to that is you'll have less chances of squeaking, and less worries about premature brake failure due to worn/damaged rotors.
Old Dec 26, 2007 | 10:43 AM
shankrabbit's Avatar
shankrabbit
On top of that, your old rotors were worn to the shape of your old pads, you want your new pads to create their own shapes and grooves from a blank canvas. (also know as "bedding")
Replace!
Old Dec 26, 2007 | 10:52 AM
OctaneGuy's Avatar
OctaneGuy
Depends. How many miles are on your rotors? How many brake pad changes have you done?
Old Dec 26, 2007 | 04:57 PM
Greg S's Avatar
Greg S
Word from my service department is that the MINI rotor cannot be turned. We just had our 06 in for replacing the front brake pads and they put in a new set of rotors and pads. Our tech told me he makes a point of letting people know that the rotors cannot be turned and how much the brake job is, $600, so that they don't get surprised when it has to be done out of warranty.
Old Dec 26, 2007 | 05:07 PM
hemiheaded18's Avatar
hemiheaded18
Every person I've talked to has told me that rotors can't/should not be turned on a European car. I don't know why but I've always followed that. Softer metal maybe? Its not worth the effort anyway. Brembo blanks can be had for 40 for fronts, 60 for rears. There are other choices (read:more $$$) if you so choose.
Old Dec 27, 2007 | 07:50 PM
JAGFIXER's Avatar
JAGFIXER
You can get dimpled and slotted rotors on Ebay for $164 for all for wheels. I got mine and the rotors are excellent with EBC green pads. Did rotors. pads and stainless braided lines for under $500.
Old Dec 27, 2007 | 08:31 PM
Ancient Mariner's Avatar
Ancient Mariner
Most stock rotors now don't have enough "meat" on them to be turned and still leave enough thickness to prevent warping. By the time you turn them to eliminate normal wear and grooving, they are at or very near the stamped 'minimums'. Not worth the bother.
Old Dec 28, 2007 | 08:20 AM
PenelopeG3's Avatar
PenelopeG3
Excellent quality and inexpensive brake rotors here:
http://www.zeckhausen.com/Mini/MINI_Cooper.htm
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
