Synthetic Oil required?
Old Nov 8, 2007 | 05:20 AM
05Greenie's Avatar
05Greenie
I am coming up on an oil change schedule and reading the manul it states that synthetic oil is recommended. I bought the car used from a dealer and with the purchase I was informed that my 1st 4 oils changes are free.
I called the service center to schedule an appointment and upon discussing the oils change I asked what type of oil will be used, 10W-30 non-synthetic.
Keep in mind the dealership changed the oild prior to my picking up the vehicle, so now the dealership has used non-synthetic oil and was going to use the same oil for my upcoming appointment....to me if the manul states a certian oil....that's what you use.
What negative impact will occur with non-synthetic oil?
I travel ~ 2800 miles a month...and the temperature is dropiing to ~ 30°F so,
I thinking synthetic.
Old Nov 8, 2007 | 05:30 AM
daflake's Avatar
daflake
This is a MINI dealer? BMW/MINI have been using synthetic longer than most manufacturers so I wonder of you got someone that didn't know what they were talking about.
As for your question, yes, you could run regular mineral oil in the car but with your miles, you would be changing it about once a month. Even then, I still wouldn't recommend it as your car is really designed for synthetics.
I would say thanks but no thanks. (i would call back to verify what they said though.
Old Nov 8, 2007 | 05:37 AM
05Greenie's Avatar
05Greenie
Thanks for the info and I agree.
I purchased this from a non MINI/BMW dealership...I guess that explains alot!
With the synthetic oil should I change it out at 3k miles or can I extend the mileage?
Old Nov 8, 2007 | 05:42 AM
Yucca Patrol's Avatar
Yucca Patrol
You should immediately change out the oil if they really did put regular old 10W30 in your MINI.
And if your "free" oil changes are going to be the same, I would never return to that used car dealer.
You should immediately put in a good quality synthetic oil. You do not need to change it out every 3000 miles. MINI suggests up to 15k between oil changes. I do mine about every 7k miles or so but don't freak out if I go a bit longer since I know the oil is still good.
MINI recommends Castrol. I use Mobil1 with the gold cap (NOT SILVER CAP) or Royal Purple which I get from my independent MINI mechanic.
Old Nov 8, 2007 | 05:45 AM
daflake's Avatar
daflake
Since you bought used from a non-mini dealer, I would have ti changed immediately. Castrol is the oil of choice by MINI but I use Mobil 1 5w-30 in my MINI.
Another thing to point out is that there is a service indicator in our car. When you first get in and put your key in there should be some mileage pop up in the odometer window that counts down to the next service. MINI is a 10 to 15 thousand mile interval car. Many on here have their points of view on the matter, but I have personally had my 15K oil tested at a lab and was told that it was still fine for use but on the edge of needing change. Others here will argue the low 5000 mile change. The choice is yours, but I like the extra dollars in my pocket.
Old Nov 8, 2007 | 06:21 AM
05Greenie's Avatar
05Greenie
Awesome feedback....I will change out the oil today with synthetic.
I have viewed the maintenance mileage posted with the key on position 1.
How do I reset the this once the mileage has been satisified?
Thanks again for the rapid response to my post.
Old Nov 8, 2007 | 07:11 AM
daflake's Avatar
daflake
How to reset the service interval indicator [SIZE=1]DISCLAIMER:
The information below is based on the account of a MINI2 member. Although MINI2 and the author of this thread believe this information is accurate, using it as a DIY guide is done at your own risk. MINI2 and the author are not responsible for any damage, personal injury, or warranty issues that may arise from the use of this information. Some information below may be specific to model specifications that are unique to certain countries, and may not apply to your model of MINI One, Cooper, or Cooper S.
Do not undertake any DIY project that you are not qualified to perform. If you have questions about this project, you should consult with experienced professionals and/or your MINI dealer before undertaking it. Always follow standard safety guidelines for car repair in performing DIY projects.
[/SIZE]
[SIZE=2]The only time the following procedure should be performed on a vehicle still under Full Maintenance coverage would be when an owner chose to change their own oil on a SCHEDULED oil service. Doing it at any other time during this coverage will PUSH OUT the next service![/SIZE]
To reset the service interval indicator:
push trip button
turn ignition key to position 1 and 15A will appear to left of mileage
release trip button
wait 3 seconds
push trip button
wait (5 - 8 seconds) for RST to appear in left corner
release trip button
push trip button
15000 [or kilometer equivalent] will appear as new service interval
release trip button
The miles [or kilometers] until next service will now count down from the reset interval.
Be advised that it may be a little different for the 05/06 models.
Old Nov 8, 2007 | 07:44 AM
05Greenie's Avatar
05Greenie
Thanks again....Guess what I'll be doing tonight after work.
Old Nov 8, 2007 | 07:46 AM
Yucca Patrol
What is the "trip" button?
Old Nov 8, 2007 | 09:21 AM
volki
The button in the speedometer to reset your "trip" mileage
Old Nov 8, 2007 | 09:31 AM
RA080624's Avatar
RA080624
its a button that you trip over when you get in the car
Old Nov 8, 2007 | 09:39 AM
daflake's Avatar
daflake
LOL, it is the brit version of the odometer button.
Old Nov 8, 2007 | 09:45 AM
Eric_Rowland's Avatar
Eric_Rowland
That's what you push when you want to activate the LSD.
Um, on topic - go synthetic, change every 10-15K and enjoy the MINI.
Note that you'll need a 36MM socket to remove the oil canister.
Old Nov 8, 2007 | 09:54 AM
05Greenie's Avatar
05Greenie
What an awesome site....soooo many people willing to help out.
Old Nov 27, 2007 | 10:54 AM
Candog's Avatar
Candog
Reset Oil Change Interval
FYI, I just used the above procedure to reset my oil change interval indicator and it work great. I had to try it 3 times but it finally reset. My next interval is showing 15,500 Miles but I'm sure I'll change it again before that.
Tom
Old Nov 27, 2007 | 11:17 AM
05Greenie's Avatar
05Greenie
Me too...thanks to the information from daflake the odometer maintenance mileage was reset.
Since changing out the oil from mineral type to synthetic my engine runs very smooth. I plan to go 10k miles on this oil, I'll let you know when I have the information avaliable.
Thanks again everyone!
Old Nov 27, 2007 | 12:40 PM
daflake's Avatar
daflake
You are welcome guys.
Old Nov 27, 2007 | 12:52 PM
sequence's Avatar
sequence
I would really wonder if this dealer even changed the filter, since it is a non-conventional canister-type and not spin-on. id change that as well.
Old Nov 27, 2007 | 11:03 PM
daflake's Avatar
daflake
Recommend that with every oil change...
Old Nov 28, 2007 | 04:45 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I change my oil filter every 5k and I plan on doing oil changes every 15k from now on. Yes my car only has 37k on it, but I had to add/replace oil a few times for various reasons. My last oil and filter change was at 30k, filter at 35k.
Old Nov 28, 2007 | 07:44 AM
mnhunt's Avatar
mnhunt
Mobil has an extended service synthetic oil you may wish to consider, good till 15K or your service interval. I have alway been a Castor Oil fan, but It seemed worth a try. It has been a bit hard to find. The discount stores are always out of it. I did find it at a NAPA dealer, but only after checking 3 of them.
Old Nov 28, 2007 | 09:54 AM
MiniStupidfun's Avatar
MiniStupidfun
Originally Posted by daflake
How to reset the service interval indicator [SIZE=1]DISCLAIMER:[/SIZE]
[SIZE=1] [/SIZE]
[SIZE=1]The information below is based on the account of a MINI2 member. Although MINI2 and the author of this thread believe this information is accurate, using it as a DIY guide is done at your own risk. MINI2 and the author are not responsible for any damage, personal injury, or warranty issues that may arise from the use of this information. Some information below may be specific to model specifications that are unique to certain countries, and may not apply to your model of MINI One, Cooper, or Cooper S. [/SIZE]
[SIZE=1] [/SIZE]
[SIZE=1]Do not undertake any DIY project that you are not qualified to perform. If you have questions about this project, you should consult with experienced professionals and/or your MINI dealer before undertaking it. Always follow standard safety guidelines for car repair in performing DIY projects. [/SIZE]
[SIZE=1] [/SIZE]
push trip button
release trip button
wait 3 seconds
push trip button
release trip button
push trip button
release trip button
worked like majic
Old Apr 14, 2008 | 04:29 AM
davavd's Avatar
davavd
Why? What is the difference?
Old May 3, 2008 | 06:59 PM
BlueBonnet's Avatar
BlueBonnet
I just put in 0-40 Mobil 1 . . . I didn't notice the color of the cap. I chose it because 5-30 doesn't cover the range of ambient temperatures in which I operate the car and because it meets the BMW LL-01 specification. I had bought some Castroil 10-40 but after doing some reading here on NAM checked and saw that all the the 10-XX Castroil's don't meet the BMW specification.
IMO I think reading the label is he way to go. I'm not sure cap color is the secret.
Ah, the reset worked magic. Mine said 51 not 15. Mine reset to 15,500.
Colt45Magnus
Jul 14, 2019 06:18 PM
yukinoinu
Sep 20, 2015 09:10 PM
panerai21
Aug 18, 2015 02:15 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
