So the MINI wouldn't start on Friday...
Old Aug 6, 2007 | 11:06 AM
subieworx's Avatar
subieworx
Strange problem. I go out to the parking lot after work, unlock the door with the keyless entry, put the key in the ignition, foot on clutch, press the button and nothing.....all I hear are three little clicks coming from the steering column. Try again, same thing. Try quite a few more times with no change. Take the key out put it back in, no change. Figuring something strange could be happening electrically I reset the battery by pulling the neg terminal. Try again, same result....three clicks. I figure something has to be up with the steering/steering column/keyless entry system, so I get my head really close to the wheel to see if I can hear the clicks better, press the start button and...it starts. When it did this I noticed the wheel turned to the right about an inch or so.
This got me thinking. With a normal key activated ignition, the steering wheel sometimes becomes locked and will not allow the key to be turned to the start position. Normally this problem is solved by wrestling with the steering wheel a bit to get it to unlock and allow the key to be turned. I believe this is what happened in this case as the wheels were not pointed straight ahead when I turned the car off, but because there is no key that cannot be turned indicating the wheel is locked you have no way to tell that is the problem.
Moral: if you find your car not starting and onyl hear three clicks coming from the steering column, give the wheel a tug in both directions and try again.
Tony
Old Aug 7, 2007 | 05:06 AM
djam43's Avatar
djam43
Thanks for the info.
Old Aug 7, 2007 | 05:47 AM
Arnbut's Avatar
Arnbut
My yellow car did the same thing one time. I think it has something to do with the electric steering wheel lock. Maybe if you get in the car hard/heavy it upsets the lock and the car thinks somebody's stealing it?
Just a guess...
Old Aug 31, 2007 | 12:02 PM
lacning74's Avatar
lacning74
Happened to me today. The attendant and then me put the key in, pressed the start button and only heard those clicks coming from underneath the steering wheel. Thought I was stuck in the bowels of Manhattan in a parking garage. I even called roadside to jump start or tow my car. None of the parking attendants were helpful.
I then noticed the "electric steering wheel locked" symbol on the tach display. If it was on the whole time, I never noticed it. I turned the steering wheel, and then the car started.
I felt stupid. I'm used to not being able to turn a key when the steering wheel locks. They should make the start button shock you or something equivalent when the steering wheel locks.
Old Sep 1, 2007 | 08:10 AM
cob666's Avatar
cob666
I've had a similar issue but I wasn't able to even get the key in if the steering wheel is locked and I'm on a hill (so there must be some preasure on the lock mechanism.) I've also had problems getting the key OUT when parked on said hill.
But now I know what the issue is and make sure I can jiggle the steering wheel a bit.
Old Sep 1, 2007 | 08:16 AM
GEP's Avatar
GEP
Did you experience this in your R56? If so, what model and type of transmission?
Old Sep 1, 2007 | 08:18 AM
GEP's Avatar
GEP
Tony
What year/model/transmission type for this problem?
Old Sep 3, 2007 | 09:35 AM
lacning74's Avatar
lacning74
2007 R56 MC automatic. I wonder what the parking attendant did to activate the lock.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
kpl
Aug 11, 2015 04:52 AM
