Inconsistant Startup Idle
Old May 25, 2003 | 10:18 PM
ball7068's Avatar
ball7068
I noticed that sometimes when I start the car, it idles at about 750-800rpms. Other times though it is closer to 1100-1200rpms. Haven't found any predictable factor, like weather or temp. Any ideas?
Erik
Old May 26, 2003 | 07:01 AM
edlfrey's Avatar
edlfrey
>>Erik
My Nov '02 build Cooper had a "fluctuating idel" that may be what you are seeing. At start up it would move up and down within the ranges that you are experiencing. An ECU upgrade seems to have taken care of the problem.
Old May 26, 2003 | 08:00 AM
nfo's Avatar
nfo
another factor is the A/C being on!
it will idle higher with it on!
Old May 26, 2003 | 08:28 AM
ball7068's Avatar
ball7068
Good call! I'll have to pay attention to that and see if that's whats causing it.
The idle doesnt fluxuate, its either stays in the 750-800 range, or its in the 1100-1200 range and is consistant...so I don't think it would be the ECU like edlfrey mentioned.
Thanks,
Erik
Old May 26, 2003 | 08:36 AM
Ryephile's Avatar
Ryephile
my March '03 build MCS has "normal" idle I'd say, it's about 1k RPM during warmup, and about 700 RPM when it's warm. No weirdness, and always predictable.
You may have a sensor gone bad, and be mindfull of your accessories, and also perhaps a fresh ECU update is in order.
Good luck!
Cheers,
Ryan
scfiveo
Sep 27, 2019 02:27 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
