MINI logo on steering wheel peeling off
Old Dec 26, 2007 | 11:08 AM
  #26
PiNioN's Avatar
PiNioN
I had my airbag assembly replaced w/in 6 months of purchasing my '06 due to the emblem lifting on the right wing tip. The dealer told me it is my fault and caused by me hitting the horn to hard. They informed me that they would replace it as a good faith gesture, but in the future, if it were to happen again, they will not replace it.
It has now been 1 year since my previous replacement and at my next service I will be talking to the dealer about replacing the assembly again....we will see how this goes.
Old Jan 3, 2008 | 04:40 PM
  #27
creseida's Avatar
creseida
Mine in my 06 is fine but a friend has an 05 MCCa that the logo peeled up on. The dealer tried to tell them it was his fault then finally relented and replaced the air bag assy. When my MINI went in for its annual service and some minor warranty issues, the loaner they gave me also had a peeling logo.
Old Jan 3, 2008 | 05:11 PM
  #28
lilruffcat's Avatar
lilruffcat
I have a hyper blue 06 too.. and my logo doesn't lay flat.. down on the lower right hand corner its raised slightly... Ill have to have it checked out next service
Old Jan 3, 2008 | 05:26 PM
  #29
1QukMINI's Avatar
1QukMINI
Mine is bubbling, too. Can't they just replace the logo sticker?
Old Jan 4, 2008 | 11:32 AM
  #30
vargasgal's Avatar
vargasgal
I had the first one replaced around 27000 miles....noticed the replacement one peeling up from right side about 5000 miles later. I had honked the first time around. I haven't honked since the replacement. If it is due to improper honking , then why is mine peeling up when I have never touched it?
It is a design flaw. The emblem is designed to be the weak point of the airbag assembly so that it can inflate easily in the event of an accident. The designers should have come up with a different design with the new car. I can't imagine that at $800 a pop under warranty, MINI doesn't know about this flaw.
Old Jan 4, 2008 | 12:51 PM
  #31
MarcoEsc's Avatar
MarcoEsc
'05 MCSc; right wing of logo is poking up, just like the rest of you described. We'll report it when in for our next service.
Old Jan 4, 2008 | 01:47 PM
  #32
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
Fiancee's car is peeling up on one side. Took it to MINI and they would not replace it as I was told, "Someone has pushed the horn in the center and not the edges, making the logo ends come up."
Those that got yours replaced are lucky!
Old Jan 4, 2008 | 02:42 PM
  #33
vargasgal's Avatar
vargasgal
Lucky...no. We just have a Service Advisor with a little integrity.
That is the most ridiculous excuse I have ever heard. I guess they should put a warning sticker on the steering wheel if that is the case.
How do they explain it happening without the horn being honked? I was paranoid that maybe my horn honking had been excessively forceful so I was very conscious to not hit the horn anymore.
Old Jan 4, 2008 | 02:49 PM
  #34
bahawton's Avatar
bahawton
The same thing happend to me at 7K miles!
I hope it doesn't happen again or I'll have to pay a "special" visit to the local dealer....
Old Jan 5, 2008 | 05:01 PM
  #35
teachinkids's Avatar
teachinkids
This thread only mentions R53s. Is this same issue happening in the R56s?
Old Jan 5, 2008 | 05:16 PM
  #36
Sin MINI's Avatar
Sin MINI
Took mine in for service and they WOULDN'T replace the airbag. Said my bending the logo wasn't covered by the warranty. During the "discussion" that followed I learned that the the horn is in fact on the sides and not in the middle. Now they tell me. So I'm looking now to remove and replace the logo with a sticker from Aesthetic Creations.
Old Jan 6, 2008 | 11:11 PM
  #37
Sin MINI's Avatar
Sin MINI
Well, I just read the user's manual and guess what...it shows the horn in the center, not the sides.
I'm gonna have another "discussion" with these folks.
Old May 14, 2008 | 06:41 PM
  #38
Quesera's Avatar
Quesera
My logo bent today. i used my horn, but definitely didn't pound it or anything. Hmm... i wonder what my MINI SA will say.
Old May 14, 2008 | 06:53 PM
  #39
PenelopeG3's Avatar
PenelopeG3
We used the horn often when we were in NY.
It doesn't take much pressure to bend the cheap plastic POS and have it come up at the edges. They replaced it once for us and told us not to do it again.
You can probably peel it off, straighten it and glue it back on. That would probably be less effort than trying to argue with the dealer.
Old May 14, 2008 | 09:39 PM
  #40
sshaynak's Avatar
sshaynak
I had the same problem with my MCC in the first week, and the SA told me the whole airbag needed to be replaced because the logo covers a sensor (or some other working component). If what they said is true, then I don't know how making a cosmetic fix may affect the operation of the airbag. My dealer replaced it without a fuss.
Has anybody noticed that all these problems seem to start with the right wingtip?
Old May 14, 2008 | 09:44 PM
  #41
nabeshin's Avatar
nabeshin
Functioning Lunatic
I'm glad I have the '02 wheel design. I use the reflective nature of it as a basic mirror of sorts to make sure my harness pads are even.
Old May 14, 2008 | 10:16 PM
  #42
Duck360198's Avatar
Duck360198
mine's peeling up on the right corner....but I'm not too concerned about it, YET
Old May 15, 2008 | 05:57 AM
  #43
MacBones's Avatar
MacBones
Mine has been poking up on the right side since day one - Hasn't gotten any worse so I'm hesitant to say anything about it to the dealer. They (Nick Alexandar MINI) just had to remove my airbag to replace the steering column (wasn't holding it's position). Leaving two poked holes in the collar that goes around the top of steering column...very annoying. I was thinking of taking it to Universal MINI to see if the holes are normal operating procedure (seems odd that work on the car leaves damage). Maybe I'll ask about the logo at the same time.
Old May 19, 2008 | 11:34 AM
  #44
astrochex's Avatar
astrochex
Just noticed mine is starting to lift on the RHS.
I'm taking the car in for another item so I will have them check this also.
Old May 19, 2008 | 10:01 PM
  #45
Ancient Mariner's Avatar
Ancient Mariner
I, too, share the pleasure of the '02 design. To check my part and make sure there is nothing in my teeth. Although there seems to be some minor flaking going on. The logo, not my teeth.
Old May 30, 2008 | 06:33 AM
  #46
ozarkgolfer's Avatar
ozarkgolfer
Originally Posted by Louispup
Peeled up from the right twice, fixed twice. And once for good.
How did you fix it for good?
My logo is starting to peel on the right side as well
Old May 30, 2008 | 06:36 AM
  #47
sshaynak's Avatar
sshaynak
the only way the dealer says to fix it is an airbag assmbly replacement.
Should be covered.
Old May 30, 2008 | 06:43 AM
  #48
dickdavid's Avatar
dickdavid
This is obviously a design flaw and I wish MINI would own up to it. Mine was peeling up since day 1, but since it's bent from horn usage, they won't replace the air bag.
I don't want a new air bag, just a new sticker. How hard would it be for them to come up with a retrofit fix for this that wouldn't require the replacement of the whole bag.
Old Jun 30, 2008 | 08:34 PM
  #49
05 GoKart's Avatar
05 GoKart
Is this warranty or dealer-pay good will?
Does anyone know who is paying for the fix?
My '05 Cabrio S was fixed once by the dealer under (they said) "good will" which means the dealer eats it. Now, only a few months later--and with NO POUNDING on it--it's doing it again. The dealer (NW Mini, Fife, WA) says they're not fixing it again.
They also said it's $900 to replace the driver's side airbag assembly, required to replace the p.o.s. metal logo.
Has anyone contacted MINI re this? I'm thinking of showing up at MTTS LA with a big LEMON sign on the side of my car because at 33,000 miles I also have a driver's seat that's wearing out and a convertible top that shows the outline of the structural supports.
Damn good thing it's FUN to drive!
Old Jul 3, 2008 | 01:59 PM
  #50
MarcoEsc's Avatar
MarcoEsc
When we took the car in for our next scheduled service, they replaced the airbag assembly and also told us it was a "one time" thing. Then we got the talk about the proper way to honk the horn.
