FS:: Genuine Drew Technologies Mongoose ISO/CAN J2534 Interface Cable
Category: Interior
Price: $200
https://www.northamericanmotoring.co...and-j2534.html
The Mongoose and MongoosePro ISO cable will cover the following pins on the OBDII
5 - Signal Ground
6 - CAN+
7 - K-Line (ISO9141)
14 - CAN-
15 L-Line (ISO9141)
16 - Battery
Any OEM that only require these protocols you can use the cable. The Mongoose ISO (clear case) will not work with Windows 10.
VW/BMW/Mini/Chrysler all can use ISO9141
Most OEM 2008 and newer use HS-CAN on 6 & 14 for emission modules
The Mongoose/MongoosePro ISO is more of an engineering interface, however it can be used for programming.
Dave ***
OPUS | IVS Technical Support
support@drewtech.com
support@drewtech.comsupport@drewtech.com
5 - Signal Ground
6 - CAN+
14 - CAN-
15 L-Line (ISO9141)
16 - Battery
Dave ***
Overview
Mongoose® is a low-cost, high-performance vehicle network interface that connects a laptop directly to the OBD-II connector. We designed this product to be an affordable USB to CAN and USB to K-line interface for OEM engineerin, development, enthusiasts, and hobbyists. Automotive technicians considering this should look at the Mongoose® MFC. The package includes:
* Mongoose® vehicle interface
* Installation CD with device driver (J2534 compatible)
The Mongoose® includes a J2534 driver and delivers full-speed (12mps) USB 2.0 performance. This version is compatible with most European and Asian vehicles. Please verify compatibility before ordering.
Features
* Key Features
o Low cost, high performance pass-thru tool for use with PC
o USB Diagnostics tool for CAN and ISO9141 vehicles
o Simple packaging with electronics contained inside the cable.
* Bus Protocols
o CAN Bus (capable of ISO 15765, GMLAN, J1939, and ISO14229)
o KWP2000 (ISO9141 / ISO14230)
* Other
o J2534 and J2534-1 compliant device driver
o Commercial Range (0 to +70 C)
o Dimensions: 3" x 1.75"
o Operating Voltage: Bus-powered by USB
o Host Interface: Full-speed 12 mbps USB 2.0 with J2534 device driver
Navigation & Audio Can anyone tell me the BMW/MINI Part Number for the iPod Y adapter to USB and 1/4"
CheshireSmile
Navigation & Audio
May 7, 2008 10:06 PM
aldoushett
Jan 28, 2008 09:54 AM
