FS:: Adaptec 4x100 to 5x112 adapters
Old Sep 19, 2017 | 05:56 PM
Alex Hamby's Avatar
Alex Hamby
Category: Wheels & Tires
Price: $200
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60
Location (Region): Midwestern
Selling a set of four Mini-specific adapters made by Adaptec. 4x100 to 5x112. Good for Mercedes and Audi wheels, along with all aftermarket 5x112. Two 25mm and two 30mm thick. Lug AND hubcentric. These adapters also adapt the center bore to 66.56, perfect for the majority of 5x112 wheels, however could still be machined down for a smaller centerbore.
Includes all pieces needed, everything in great condition, ready to install. Asking $200 shipped. Adaptec charges $375 + shipping for any set of adapters they make. Also comes with lifetime warranty. Happy to answer any questions, just PM me. Thanks!
Attached Thumbnails Adaptec 4x100 to 5x112 adapters-20170830215657_img_7178.jpg   Adaptec 4x100 to 5x112 adapters-20170830215716_img_7180.jpg   Adaptec 4x100 to 5x112 adapters-20170830215738_img_7182.jpg   Adaptec 4x100 to 5x112 adapters-20170830215800_img_7184.jpg   Adaptec 4x100 to 5x112 adapters-20170830215812_img_7185.jpg
Adaptec 4x100 to 5x112 adapters-20170830215824_img_7186.jpg   Adaptec 4x100 to 5x112 adapters-20170830215836_img_7187.jpg   Adaptec 4x100 to 5x112 adapters-20170830215845_img_7188.jpg   Adaptec 4x100 to 5x112 adapters-20170830215905_img_7189.jpg   Adaptec 4x100 to 5x112 adapters-20170830215643_img_7177.jpg
Old Oct 13, 2017 | 09:43 AM
Alex Hamby's Avatar
Alex Hamby
bump. Shoot me an offer if interested!
Old Oct 20, 2017 | 09:23 AM
gumbedamit's Avatar
gumbedamit
Hello, do you still have the adapters and are they the same as the following:
https://cimg5.ibsrv.net/gimg/www.nor...4e6138485c.jpg
https://www.northamericanmotoring.co...dest-look.html
I purchased the 2nd set of BBS's from Jacob and looking to get them mounted. Check out his post and tell me if they will fit, thanx
Old Oct 21, 2017 | 07:40 AM
Alex Hamby's Avatar
Alex Hamby
Your adapters are 5x114.3, these are 5x112 so unfortunately no they are not going to be the same unless your second set of BBS's are 5x112.
Old Oct 23, 2017 | 06:15 AM
KCLARK's Avatar
KCLARK
i see these have a hubring on them for the 5-112 wheel, but what about on the inside. these dont need a hubcentric ring for the "mini" hub which is 56.1 to fit snug? I never understood these adapters so that's why im asking.
Old Oct 24, 2017 | 09:12 PM
Alex Hamby's Avatar
Alex Hamby
If you look on the back side of the adapters, you'll see its simply flat with the hub hole. This hole diameter is 56.1, so will fit as snug as possible without a hub ring. Then on the front side, that hub hole now has a flange around it, thus requiring the aftermarket 5x112 wheel to have a larger hub. In this case, 66.6 because that's what the majority of 5x112 wheels have for a hub bore.
Old Nov 23, 2017 | 10:19 PM
gfr53's Avatar
gfr53
PM sent
Old Oct 6, 2020 | 10:03 AM
MINI.FISHBOWL's Avatar
MINI.FISHBOWL
Hi, are the adapters still available? If not, can you tell me where you bought the adapters at because I wanna run some 5x112 wheels I have on my R56.
Old Oct 6, 2020 | 10:12 AM
MINI.FISHBOWL
Question
I know this is a long shot but are the adapters still available?
Old Oct 10, 2020 | 10:02 AM
slademan's Avatar
slademan
Three year old thread. Most likely not. They aren't hard to find from a google search. Good luck.
