R50/53 2006 MCS 6MT LSD Slickroof in SBM
Old 07-16-2018, 07:41 PM
RedAggie03's Avatar
RedAggie03
RedAggie03 is offline
Replaced the power steering lines
While the power steering pump and mount was out, I cleaned everything up really well
I also drilled and tapped the oil pan for my oil temperature sensor so I don’t have to fiddle with it at every oil change
  #102
Old 07-18-2018, 01:32 PM
ssean72's Avatar
ssean72
ssean72 is offline
Very clean car, my favorite color for sure, I always enjoy reading all the build treads, and seeing what everyone else is doing.
  #103
Old 07-20-2018, 09:01 PM
RedAggie03's Avatar
RedAggie03
Tonight I drilled out the oil drain plug hole which the previous owner had stripped out. The plug was a “oversized” M14 self-tapping plug. Yuck. It was leaking a little and I just don’t tolerate that. So it’s now a M16 and has a Fumoto.
ECSTuning (07-23-2018)
  #104
Old 07-22-2018, 08:49 AM
RedAggie03's Avatar
RedAggie03
Got her all put back together, looking good as new!
  #105
Old 07-22-2018, 02:45 PM
RedAggie03's Avatar
RedAggie03
My lil helper tightening the reservoir nuts for me
  #106
Old 07-23-2018, 07:59 AM
Received 1,979 Likes on 1,776 Posts
Coming along great and glad to see a helper starting young.
  #107
Old 08-01-2018, 02:21 PM
RedAggie03's Avatar
RedAggie03
Finished my oil temp sensor install - I used the following sensor:
  #108
Old 08-03-2018, 08:47 AM
RedAggie03's Avatar
RedAggie03
Finished up my oil temperature sensor install today. I needed to run the wire from the gauge down to the sensor. I routed it very cleanly and out of the way of everything as best as possible. Turned out pretty nice.
A little warm up in the garage to check it's functionality. Yes, it's in Celsius... At least my Canadian wife will be happy.
After a bit more warm up and a little spirited driving along the service road
View of the cluster of gauges. I also have a Marshall boost gauge up on the dash where it's easier to see.
Thanks for checking out my thread
  #109
Old 08-03-2018, 08:54 AM
RedAggie03's Avatar
RedAggie03
Also, I don't think my PS fan is working. I was watching it while the car ran in the garage and it never kicked on. The radiator fan would kick on for about 5-10 seconds and then off for 20-30, but the PS fan never worked. When I had it off to service the powersteering pump and replace the lines, I cleaned it up well but I noticed that it would barely spin. I'd be surprised if that little motor could spin something that tough to spin by hand. So I guess I'll be ordering one of those as well...
  #110
Old 08-03-2018, 10:15 AM
Zsm's Avatar
Zsm
Zsm is offline
Gauges look great! That's a project I'll get to one of these days.
Maybe it's the angle, but it seems your voltage is low. Through the OBC hidden menu when monitoring voltage, I usually see 12.5+ volts at idle and 13+ while driving. We replaced the alternator with a rebuilt back in 2016. Is your alternator original?
As for the power steering fan, it should come on when engine is on. Get that replaced!
  #111
Old 08-03-2018, 11:52 AM
RedAggie03's Avatar
RedAggie03
When the car is at low idle and everything is running it can dip down, but normal driving it's always well over 12 volts. I'm pretty sure it's the original alternator. I don't know, but so far the car show no issues of any kind of electrical problems. I also don't drive the car much, so it's entirely possible that the battery is just actually low. <shrug>
  #112
Old 08-04-2018, 11:33 PM
Zsm's Avatar
Zsm
Zsm is offline
Alright, what’s your formula for cleaning and detailing the under carriage? I didn’t see your process. Your results look fantastic!
  #113
Old 08-06-2018, 11:32 AM
RedAggie03's Avatar
RedAggie03
Orange clean since you do not need to rinse it with water like you do with simple green and brushes. Spray it down, let it soak for a minute and then scrub. Clean the brush frequently and wipe down as much as you can with microfiber cloths. Lots of raw knuckles....
  #114
Old 09-10-2018, 01:07 PM
RedAggie03's Avatar
RedAggie03
Replaced the power steering fan... Everything is working perfectly now and she's dry as a bone underneath. Feels quite good to have her 100% sorted out for now and running great.
  #115
Old 09-24-2018, 09:47 AM
RedAggie03's Avatar
RedAggie03
She just rolled over 69,000 miles
  #116
Old 12-20-2018, 01:09 PM
RedAggie03's Avatar
RedAggie03
Update... The car has been sold. I found a great deal on a pretty rare Volvo C30 R-Design that my wife and I really love and we bought it. I had not planned on selling the MINI, but it had to go. It is off to a new owner now and I hope he'll join the forums and continue the story of this great little car.
Cheers!
