R50/53 2006 MCS 6MT LSD Slickroof in SBM
#101
Replaced the power steering lines
While the power steering pump and mount was out, I cleaned everything up really well
I also drilled and tapped the oil pan for my oil temperature sensor so I don’t have to fiddle with it at every oil change
#106
Coming along great and glad to see a helper starting young.
#108
Finished up my oil temperature sensor install today. I needed to run the wire from the gauge down to the sensor. I routed it very cleanly and out of the way of everything as best as possible. Turned out pretty nice.
A little warm up in the garage to check it's functionality. Yes, it's in Celsius... At least my Canadian wife will be happy.
After a bit more warm up and a little spirited driving along the service road
View of the cluster of gauges. I also have a Marshall boost gauge up on the dash where it's easier to see.
Thanks for checking out my thread
#109
Also, I don't think my PS fan is working. I was watching it while the car ran in the garage and it never kicked on. The radiator fan would kick on for about 5-10 seconds and then off for 20-30, but the PS fan never worked. When I had it off to service the powersteering pump and replace the lines, I cleaned it up well but I noticed that it would barely spin. I'd be surprised if that little motor could spin something that tough to spin by hand. So I guess I'll be ordering one of those as well...
#110
Gauges look great! That's a project I'll get to one of these days.
Maybe it's the angle, but it seems your voltage is low. Through the OBC hidden menu when monitoring voltage, I usually see 12.5+ volts at idle and 13+ while driving. We replaced the alternator with a rebuilt back in 2016. Is your alternator original?
As for the power steering fan, it should come on when engine is on. Get that replaced!
#111
#113
Orange clean since you do not need to rinse it with water like you do with simple green and brushes. Spray it down, let it soak for a minute and then scrub. Clean the brush frequently and wipe down as much as you can with microfiber cloths. Lots of raw knuckles....
#114
#116
Update... The car has been sold. I found a great deal on a pretty rare Volvo C30 R-Design that my wife and I really love and we bought it. I had not planned on selling the MINI, but it had to go. It is off to a new owner now and I hope he'll join the forums and continue the story of this great little car.
Cheers!
Cheers!
