FS:: (VA) TR motorsport wheels 15x8 +20 w/ 195/55 falken 512
Old 10-01-2013, 03:46 PM
ROOSEY's Avatar
ROOSEY
ROOSEY is offline
Category: Wheels & Tires
Price: $550
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57
Location (Region): SouthEast
selling my set of tr motorsport C1 wheels. the specs on them are 15x8 +20 4x100 bolt pattern, should fit all the models listed. the r56 and r57 may need the holes drilled out to fit the larger stud. not a 100% sure on that as i do not own a r56.
these wheels would make an awesome set of track wheels, autocross wheels or just a nice set of aftermarket wheels. they're pretty lightweight and a definite upgrade over stock wheels. i had these on my car with h&r lowering springs and they fit real nice. gave it a good aggressive stance with the lower offset. if lowering on coilovers i will advise they might need some camber so they don't rub.
the wheels have zero curbage, dings, dents, or bends. only issue is one of them has some corrosion on it where the corners of the spoke meet the rim. no idea how that happened as they are only about 3k miles old. it's not bad by any means(third picture shows this) tires are also in great shape they are a 195/55 with 3k miles on them. the bigger sidewalls make them comparable to a 205/50. only went with the 195 as it creates a slight stretch in the tire to help with fitment. wheels truly look awesome on the r53.
i'd keep these wheels all day but i had to go with a 17" rim so i could fit my new wilwood brakes . i have no use for these...looking for pick up only. I'm located in Virginia Beach. but will drive an hour or so to meet if youd like to purchase.
any questions just shoot me a text or something at 814-323-6142
Thanks!!!
Attached Thumbnails (VA) TR motorsport wheels 15x8 +20 w/ 195/55 falken 512-wheelsssss.jpg   (VA) TR motorsport wheels 15x8 +20 w/ 195/55 falken 512-guns.jpg   (VA) TR motorsport wheels 15x8 +20 w/ 195/55 falken 512-corrosion.jpg
eatsleepautox
10-30-2015 06:46 AM
etidd01
09-07-2015 05:19 AM
TOMSR53
08-26-2015 10:18 AM
sabjcw
08-14-2015 07:40 AM
Quick Reply: FS:: (VA) TR motorsport wheels 15x8 +20 w/ 195/55 falken 512
