Solo Help!! Wheels for HS!!
Old May 5, 2004 | 05:01 AM
satay-ayam's Avatar
satay-ayam
I'm looking at this wheel at the tire rack: Click (edit, link no worky? Oh well, all the relevant info is listed below - this is a 16X6.5 wheel called the Fox 3 or something - I'm not ready to drop the cash on SSR's just yet)
The offset listed for this is 42mm. In the HS forum, it says that the 16" OEM wheel should have a 50mm offset. In the GS forum, it says that the 16" OEM wheel should have a 48mm offset. Do the Cooper and Cooper S really use different offsets?
If we are allowed +/- 0.25 inches in offset, it would be (barely) legal if the 48mm number is correct for HS. If we are allowed 5mm, it is barely not legal for stock. If I really need 50mm for stock, then there's no hope.
So what's the deal?
I want to be letter of the law legal, since even though I'm not that hot of a driver, I do plan on going to nationals this year.
The other option is 15" wheels. I already have a set of 15" victoracers (but no wheels) that I had planned on using, but my tire guy is trying to steer me into a 16" setup. He'll take the victos back at no charge.
thanks in advance for edumacating me!
_________________
Roger B - slow but happy autocrosser
where's my MINI? - FINALLY IN MY GARAGE!!!
Old May 5, 2004 | 05:13 AM
BGarfield's Avatar
BGarfield
Many of the wheels are stamped right on there...48mm. .25 inches is just over 6mm if I remember correctly, so the 42mm should be legal.
I can't use the link, is the wheel 16x6.5? Remember that it must be stock diameter AND width.
So you know, I've got a set of MINI wheels AND unused Ecsta V700's mounted for sale.
Brian
Old May 5, 2004 | 05:22 AM
satay-ayam's Avatar
satay-ayam
Brian - thanks for your quick reply!
The wheel is listed as 16 X 6.5. Sorry the link doesnt' work, I'll try to track it down later. If you're really curious, you can find it on the tirerack site. This isn't anything fancy, it's a $124 wheel, but it is apparently the right size. At 20lbs it isn't exactly light, but oh well, my driving isn't exactly national calibre, either, so who am I to complain.
0.25" = 6.35mm. So I should be safe then.
If I didn't already have these 15" tires, I'd buy your set, but this guy is doing me a favor with pricing and is an overall great guy, so it wouldn't really be appropriate to give him the tires back and take my money someplace else.
Thanks again!
Old May 5, 2004 | 05:38 PM
JustGo4It_'s Avatar
JustGo4It_
Fox 3
I think you would be much better off with a set of AK Monzas. 13.9 pounds and $155.
They are SSR knockoffs. You want the lightest wheels you can afford. You can get them at Webbmotorsports
_________________
James - SCCA SFR GS # 96
Old May 6, 2004 | 08:13 AM
conecarver's Avatar
conecarver
I have a set of the Monzas... got mine from AK tire in MIAMI.... I also have a set of 7 hole 15" wheels that I had 710s mounted on.... If you can find a cheap set of 7 hole wheels they are very light... 12 pounds... I don't think the 15" setup gives up much compared to the 16s.... a few tenths given equal tires...
Old May 6, 2004 | 07:26 PM
satay-ayam's Avatar
satay-ayam
Thanks for the advice guys!
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
