R60 :: Countryman Talk (2010-2015) R60 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
Sponsored by: DashLynx
R60 Turbo holding back
Old 07-12-2018, 04:51 AM
rotaryferreira's Avatar
rotaryferreira
rotaryferreira is offline
Turbo holding back
Has anyone experienced a situation where when you floor the car and you are in boost it feels like its holding back a bit,almost like the feeling of a clogged filter.You can actually hear the boost kind of fluttering and feel the power go and come.
Old 07-12-2018, 10:47 AM
AWD_Rally's Avatar
AWD_Rally
AWD_Rally is offline
Moderator
MarioKart might be able to answer better... I'll give it a shot.
It could be your diverter valve failing, or your wastegate needs to be adjusted to hold boost properly.
Old 07-12-2018, 12:17 PM
ke3ee's Avatar
ke3ee
ke3ee is offline
Do a search on the subject. You need Plugs if over 30k miles ( doesn't matter what the book says) and you may need Coils. Very common, can both be done in 20 minutes or less. Cost around $130 total for parts if not under warranty. Its losing spark as boost builds.
Old 07-12-2018, 12:21 PM
rotaryferreira
Car is doing exactly 30,000kms. I changed the spark plugs less than 1000kms ago though.
Old 07-12-2018, 12:29 PM
ke3ee's Avatar
ke3ee
ke3ee is offline
Then do the coils, if you did the plugs you know how easy the coils are to change
Old 07-12-2018, 06:32 PM
MrGrumpy's Avatar
MrGrumpy
MrGrumpy is offline
That sort of sounds like one of the symptoms I had when my wastegate was shot. For example, I was on the freeway and changed lanes to accelerate past another car. There was just the smallest bit of incline to the road, I would not even call it an uphill section of the road. When I pushed the accelerator the car started to pick up speed, but then just didn’t go any faster, even when I pushed down a little more on the pedal. It felt like I was driving through molasses or something, then I pushed further on the gas ...... and “Do De Doo” the dreaded half engine light and limp-mode. Funny thing is, this weird molasses moment, only happened like twice. The rest of the time it seemed to pop right into limp mode much sooner almost as soon as I tried to accelerate on an incline. The ECU wanted boost, and it just wasn’t there.
Thats why I doubt I’m being very helpful. Your turbo is probably fine, but it sounded eerily similar to what mine did a few times. Might be worth checking out if you can’t figure it out. I could still hear mine spool up fine, it just wouldn’t make enough (or hold any) boost.
Good luck! I’m curious to find out what it is.
bimmadave
06-14-2017 04:41 AM
singletrack99501
Alaska MINI Club
01-09-2011 01:55 AM
DaPooh65
06-27-2008 05:49 PM
Maaij
04-19-2008 09:21 PM
Klasse Act
05-14-2007 03:22 PM
Quick Reply: R60 Turbo holding back
