R60 All4 & electronic differential lock?
Dynamic Stability Control
Dynamic Traction Control
DSC/TC Disabled
Default: DSC on, which includes stability (yaw) control, and traction control. The system uses both brakes and throttle for control. Electronic differential lock (EDL) are subsets of DSC and are on. Limits driver control of throttle.
Press off once: DTC on, system uses brakes alone for both stability and traction functions, including EDL. Full driver control of the throttle.
Hold 3+sec. to disable DSC/DTC: Only EDL remains on to control wheel spin on left/right wheel of each axle. No stability functions active. Full driver control of throttle.
"Press the button for at least 3 seconds: the DSC
indicator lamps in the display elements come
on. The Dynamic Traction Control DTC and
Dynamic Stability Control DSC are both deactivated.
There will be no more stabilizing interventions.
Interventions (differential lock*) in braking
occur to improve propulsion when drive wheels
are rotating unevenly, even when the DSC is
deactivated."
molala
10-02-2015 01:53 PM
09-16-2015 02:01 PM
09-16-2015 01:59 PM
