R59 rear fog lights and mini service
Yes, but it's quite expensive I've been told. My MA had to have this done on her JCW ragtop , but she didn't set how much it was, other than that it was expensive.
You'll then need to have your mini programmed. Dealers probably won't do it. If you're near ATL, Way does programming too. Otherwise there's probably someone near you who can program this.
Your R59 is probably pre wired for rear fogs. You should be able to order the parts from Way. Basically a new switch plate and a toggle switch.
Dec 23, 2015 10:36 AM
