R56 Acceleration, Torque-Steer & Other Impressions
Concerning the USA spec rear view mirrors and blind spots. Are the Euro - split mirrors available (in any country) for the R56? I have, in the past, replaced USA spec rear view mirrors with the Euro - split mirrors for a great improvement. I got the Euro spec. mirrors from Canada. If the Euro spec mirrors are available for the R56 all one has to do is connect with someone willing to buy and ship for you. Or find a dealer near the Canada border who services both countries. Just a thought. ajm
MINI does have them for Europe, but they are not DOT approved for the US. See this: http://www.realoem.com/bmw/showparts...5&btnr=51_6425. MINI also have them for the 1st generation, and I obtained one through special order from UK vendor NewMiniStuff (mikeythemini, now a NAM sponser).
By the way, yet another mirror option is Multivex, which I use for the huge passenger side blind spot in the convertible, and it works great.
It can permanently damage your brain, trigger schizophrenia, and cause hallucinations years after one stopped taking it. I know a number of people who didn't survive the 1960's.
I was making a joke about the LSD acronym.
Sorry, I can't remember the '60s. I participated in them. BTW, how's Tim Leary doing?
I SERIOUSLY doubt the torque steer is all that bad!
I drove a 1.8T GTI with every bolt on before someone decided to run into it and have their insurenace company total it.
That thing had torque steer! but then again, I was asking for it.
Maybe I'm crazy, but the mini does seem to have a good amount of torque steer. Especially if accelerating from a right or left turn heavily. I've noticed my wife's '07 GTI does this less since the tire inside to the turn just usually spins freely. (NO LSD.) I've come from driving AWD cars for a few years. You just punch it and those cars go.
Any tips for driving the R56 with LSD?? I'd like to hear some from more experienced drivers.
I recall reading an article in one of the car magazines of the Acura TL when the LSD first was available on this model. This article said that LSD made the torque steer problem dramatically worse rather than better as is being reported here. Perhaps the designs are different.
My R53 has very little torque steer and I didn't notice much during my brief R56 test drive, but I don't know if it had LSD or not. This is something I'll want to clear up before commiting to a R56 - one of the things I love about my R53 is how well behaved it is for a FWD'er.
- Mark
- Mark
Well.. I turned off ASC and carved up a local twisty road tonight after work. Man... this car is unbelieveable. I think the tugging I was experiencing was mostly because of the ASC and uneven road surfaces. I also am coming from an AWD car so that may help.
Actually my AWD Evo VIII had torque steer that''d put you into a ditch. 1st and 2nd would ****** the whole car sideways, and yes put you into a ditch if your not carefull.
Yep, I'm still driving my modded 1.8T GTI and living with torque steer. I'm pretty used to it after 6 years. IMO, it just gives the car more character.
I'm confused .. First let me mention that I own an R56 S and I'm not experiencing any torque steer to speak of. Maybe once my car is broken in and I allow RPMs above 4500 I'll experience it. But maybe I'm just not noticing it. Maybe since spending years driving my '94 Saab Coupe (0-60 in 6.5 seconds), my R56 S by direct comparison doesn't suffer any torque steer at all to speak of (everything's relative .. Right).
Here's how it was in my Saab: The light turns green .. I put my foot on the accelerator and don't feel much acceleration at all (turbo lag) .. Then the turbo kicks in .. Whoa .. Exhilleration .. but hold onto that steering wheel real tight because the car is trying its best to steer itself into oncoming traffic. Now that's torque steer.
Turn on the sport button, and punch the accelerator on a slightly uneven road, and you will feel the car pull hard to one side or the other. It's just a factor of FWD design that you can't avoid. I'm used to a semi-powerful RWD car, so the behavior is quite a bit different in a turbo FWD car.
http://autospeed.drive.com.au/cms/A_3012/article.html
Torque steer on a FWD car only gets worse with more torque and, therefore, more power. The torque steer is due to one of the halfshafts that run from the transmission to the two front wheels being shorter than the other. Since one shaft is shorter it is lighter and easier to spin up to speed. This means that one wheel gets accelerated slightly faster than the other causing the "steering" effect. There are some manufacturers that almost eliminate this problem by making the halfshafts the same length, but it takes quite a bit of effort and engineering.
I've always driven FWD cars so I'm used to compensating for it but as C4 said, the best way to elminate it is a RWD or AWD car.
"Transmission choices have thankfully improved, as the five-speed manual and continuously variable transmission have been axed. Now all Coopers start with a six-speed manual, with improved synchros, including reverse. The previously S-only six-speed Steptronic automatic with manual mode is optional across the board. Propulsive forces feed out of these gearboxes through equal-length driveshafts, cutting torque steer off at the knees."
Here's the full review:
http://www.edmunds.com/insideline/do...ticleId=117072
As I said earlier, I have heard from a couple sources that LSD makes the torque steer problem WORSE, not better. Essentially the unloading and wheelspin you get without LSD is relieving the forces that cause torque steer. So with LSD you get the power down better, but the steering becomes more unruly. This is just want I've heard and I'm no authority on how LSD works or how different designs affect the torque steer problem. And I'm sure ASC is also involved. We do have a lot of people here saying their R56's with LSD have bad torque steer.
If anybody knows more about the interaction of LSD and torque steer, I'd like to hear about it.
- Mark
