R56 Torque steer
Old Feb 22, 2007 | 11:32 AM
  #51
PGT's Avatar
PGT
I know we are talking about the R56, but my R53 has LSD and that matters not with respect to torque steer.
Old Feb 22, 2007 | 11:53 AM
  #52
Bilbo-Baggins's Avatar
Bilbo-Baggins
Having read thru this whole thread I am wondering if some people are not confusing torque steer with "tramlining". The two can feel very much the same but with two very different causes.
The suspension engineers can do something to reduce TS. The engineers that spec the wheel & tire combination have a direct effect on whether or not the car tramlines.
The wider the tires the greater the tramline effect. If you are on uneven pavement while accelerating away from a stop sign or light the car can just be reacting to the pavement. Near stops the heavy wear caused by large trucks is the most pronounced. The rutting of the pavement causes the wide tires to deflect from a straight line. Whether or not you are accelerating or just trying to drive straight.
JOHO
Old Feb 22, 2007 | 11:55 AM
  #53
PGT's Avatar
PGT
tramlining isn't related to the car wanting to change lanes when you are on the gas. letting off the gas corrects the trajectory. ruts in the pavement would control the path unrelated to throttle input
Old Feb 22, 2007 | 12:42 PM
  #54
inomis's Avatar
inomis
http://en.wikipedia.org/wiki/Torque_steering
Old Feb 22, 2007 | 01:27 PM
  #55
MotorMouth's Avatar
MotorMouth
Originally Posted by Wiki
"As the Torque Steer Effect is directly related to the engine torque capabilities this problem becomes more and more evident with high output engines with strong low rpm range torque"
I've been saying this the whole time.
Old Feb 22, 2007 | 01:49 PM
  #56
inomis's Avatar
inomis
This is the best explanation why torque steer happens, even with equal length shafts etc. , that I have found:
http://www.sportcompactcarweb.com/ed..._technobabble/
I doubt the front geometry is any worse in the R56, it's just pushing a bit harder on the moment arm about the "Dave Point"(read the article ) .
Old Feb 22, 2007 | 05:36 PM
  #57
Zman's Avatar
Zman
dealer demo abuse
Originally Posted by Ken Cooper
On a car having equal length driveshafts and no unusual wear, the lone cause of torque steer is when your engine is steering the car, not you. Pounding on the accelerator causes the car to twist the direction of the tire getting more torque. But again, even if it's there when you drive hard, without the turbo lag, one can expect the torque steer to be predictable. I don't see it as a problem. When driving you just proactively compensate accordingly for the nature of the beast.
And no, I don't agree, abusing the dealer's demos (e.g. stomping on the accelerator and bringing the revs to 7000 rpm), or "driving the **** out of them", just doesn't seem right to me.
i have seen plenty of technicians and salesmen with DEMO cars abuse the heck out of them on the lot. my favorite is watching the salesman leave the showroom on a cold winter afternoon, go out, start an m3 demo, slap a dealer plate on the trunk, watch black smoke blow out the rear as he revs it, then let it idle for 45 minutes while he finishes up calls at his desk!
Old Feb 23, 2007 | 06:37 PM
  #58
Ken Cooper's Avatar
Ken Cooper
Here's a torque related quote from a February review by European Car's Karl Funke:
"The new engine on the Cooper S is every bit as powerful as the outgoing unit and then some. At full throttle, torque steer is a force to be reckoned with, but that’s par for the course on any moderately powerful front-drive vehicle. When the turbo starts to spool, hold on tight."
Unfortunately this refutes some of my earlier comments. Oh well, we live and learn.
Here's the review in full:
http://www.europeancarweb.com/firstl...mini_cooper_s/
Old Feb 23, 2007 | 06:55 PM
  #59
PGT's Avatar
PGT
yup. I once test drove an NSX and the salesguy insisted he had to drive it off the lot before I could take over. I wonder if it was required to do 140mph too on a public road before handing me the keys?
Old Feb 25, 2007 | 09:13 PM
  #60
pray4dirt's Avatar
pray4dirt
annoying
i had to test drive the new mini s on two seperate weekends just to be sure how much i didn't like to torque steer. it was annoying!!!
Old Feb 26, 2007 | 07:07 AM
  #61
GEP's Avatar
GEP
Originally Posted by minigt3
coming from a non mini owner my test drive of the MCS revealed significant torque steer in the lower gears at high RPMS( 6-7K). It was strong enough to take the car off slightly off course. Maybe I was surprise at how strong the pull was. Ordered the car nevertheless. Very smooth and quiet inside.
I have a R56 MCS with LSD, Sports Suspension and All Season Tires on 17" Crown Spoke Wheels. Starting at 2000 RPM+ in 1st. Gear, it has HUGH torque steer - pulling to the left. Less than 200 miles on the vehicle.
Old Feb 26, 2007 | 07:42 AM
  #62
justintime's Avatar
justintime
this is really making me want to test drive one just to see the power of torque steer haha. do modified supercharged s have this problem as well?
Old Feb 26, 2007 | 07:44 AM
  #63
C4's Avatar
C4
Nope.
Old Feb 26, 2007 | 07:58 AM
  #64
PGT's Avatar
PGT
yup.
Old Feb 26, 2007 | 08:00 AM
  #65
justintime's Avatar
justintime
Originally Posted by PGT
yup.
haha
Old Feb 26, 2007 | 08:04 AM
  #66
PGT's Avatar
PGT
I've got an R53 with LSD and only a 15% pulley airbox and exhaust (plus some A/S tires with lots of siping - aka lack of grip). Judicious throttle inputs are necessary when accelerating in traffic to stay in my lane. The LSD sends torque to the wheel with grip, causing torque steer. An open diff car doesn't do this (it spins the tire with no grip).
C4 - does your car have LSD?
Old Feb 26, 2007 | 08:32 AM
  #67
C4's Avatar
C4
Nope, its a '05 MCS 6MT but no LSD. Also the car is stock. I bet that if I add a 15% pulley and airbox, the torque steer will then become more noticeable. But right now if I punch it out of 1st gear the car will likly spin its wheels but not force the steering wheel out of my grip.
Old Feb 26, 2007 | 09:24 AM
  #68
Ryephile's Avatar
Ryephile
It has nothing to do with torque, and everything to do with suspension setup. My turbo R53 has about 280 lb-ft of torque and there's no torque steer. When I drive a stock R53, there's some tugging on the wheel, just like a stock R56. This isn't because of torque, it's because the cars' suspensions aren't set up to specifically minimize torque steer and maximize forward traction. Lower your roll-center, increase your scrub radius, and you'll see how torque has nothing to do with it.
Old Feb 26, 2007 | 11:12 AM
  #69
dwdyer's Avatar
dwdyer
The torque steer I've noticed so far isn't that strong. If you're a light-gripper on the wheel, maybe, but it's more of a tug than a pull.
Old Mar 29, 2007 | 08:05 PM
  #70
r56mini's Avatar
r56mini
Damn. I thought the equal length shafts got rid of torque steer. I used to have 95 Eclipse Turbo and it had a massive torque steer. Even at 60 mph, when I downshifted, it would steer hard to one side and when I first experienced it I almost hit the divider. Since then I have been driving mostly RWD cars. You guys are scaring me.... hmmm.
Old Mar 29, 2007 | 08:25 PM
  #71
eVal's Avatar
eVal
Well you don't need to buy a car based solely on other peoples opinions - don't be scared, just go for a test drive or three
Old Mar 30, 2007 | 08:54 AM
  #72
sequence's Avatar
sequence
I hate torque steer. The demo R56 I drove felt like an RSX-S/Integra or Saab or Eclipse or some other hot FWD car the way the TS made it shoot off in one direction or another under moderate-heavy accelleration--even with LSD To me, with it's equal length drive shafts and less low-end torque, R53 struck an almost perfect balance of FWD performance and lack of significant TS.
It's hard for me to look beyond this. Therefore, until MINI develops and perfects an AWD system that doesn't weigh a fracking ton (perhaps the future M/JCW?) I won't even consider an R56.
And others here who say that MINI has produced a Lexus with R56, I would think more an RSX Type S.
Old Mar 30, 2007 | 09:19 AM
  #73
r56mini's Avatar
r56mini
So in your opinion, there is less torque steer with R53. Why would the company go in the wrong direction? Maybe R56 has a lot more torque than R53.
Old Mar 30, 2007 | 10:24 AM
  #74
sequence's Avatar
sequence
r56mini I'm not sure they're going in the "wrong" direction, I think it's just the inevitibility of having MUCH more usuable low-end (and across the spectrum) torque in the new, hi-tech, aluminum block, turbo BMW-PSA mill than the old, low-tech, iron block, blown Chrysler mill that needed to approach 2500-3000 rpm to feel the low end of that engine's relatively narrow peak torque curve.
I also speak from being the owner of a bone-stock 2005 R53; those who come from S(tage)2-S3 modded or JCW'd R53s don't notice the R56s TS as much as those who have stock or lightly modded (S1) cars.
Old Mar 30, 2007 | 10:44 AM
  #75
inomis's Avatar
inomis
The only way to eliminate torque steer in a FWD car would be to stiffen the suspension to the point where it does not move, at all. Read the link I posted above. As the car and tires move around there will be points where torque steer is induced. Stiffen the car up (spring rate or stiffer bars) or loose some torque(right foot) and the R56 will show the same torque steer traits as the R53.
Also the flat torque curve on the R56 allows it's torque steer to be felt at any RPM. Put your stock suspended R53s in 2nd and hammer the throttle after cruising at 4000 RPM to get a better idea of what the R56 is like at 2000 RPM and above. You probably don't normally drive that way, but in the R56 that is normal.
