R56 R56 MC & MCS Service Schedule
Old Jan 6, 2007 | 11:27 AM
mini-s-man's Avatar
mini-s-man
Is the service schedule available for the R56S?
(pdf, Word, or a link?)
Old Jan 7, 2007 | 06:29 AM
R56MCS's Avatar
R56MCS
Servicing is by the service indicator in the rev counter not by mileage and is known as Condition based Servicing (CBS)
The MCS service book gives the floowing actions to be taken as indicated.
Check Messages in Check Control
Check indicator and warning lights
Engine Oil
Change engine oil and filter element
Handbrake; Bed down and check functioning
Charged seperatley; heating, a/c or auto a/c, change micro filter
At every 2nd oil change; change spark pugs (charged sperately)
At every 3rd oil change; Intake silencer-Renew air cleaner element is dust levels are high
Reset service display indicator.
Front Brakes
Change brake pads, clean brake caliper gaps
Brake discs; Check surface and thickness, change is neccessary (additional charge)
Rear brakes
Handbrake; Check condition, brake lining thickness and function
Change if neccessary (additional charge)
Brake Fluid
Change Brake Fluid
Reset service indicator
Vehicle Check
Brief diagnostic test
Check operation of horn, headlight flasher and hazard warning flashers
Check instrument and inscription lighting and heater blower
Check the lights
Seat belts; Check condition of belt, function of automatic reel, belt locking action and belt buckle
Check windscreen wiper and washer system
Body; Check for corrosion, except cavaties
MINI mobility system; Check expiry date on sealant bottle
Change sealant bottle if necessary (additional charge)
Tyres; Check tread wear pattern, visible condition and air pressure, correct if neccessary
Battery; Check battery, recharge if neccessary (additional charge)
Steering oil reservoir; Check the oil level top-up if neccessary (additional chrage)
Check coolant level and concentration top-up if required
Windscreen washer; Checek fluid level and top-up if neccessary (additional charge)
Brake lines and connections; Check for damage, corrosion, leaks and incorrect location
Underbody, inc all visible parts; Check for damage, corrosion and leaks
Steering Components; Check for freedom from play, leaks, damage and wear
Check- by test driving- operating safety of:
Brakes
Steering
Shock absorbers
Transmission
Pre Delivery Checks
Using BMW Group tester carry out CBS pre delivery check in the service functions path under maitenance
Deactivate transport mode
Battery test, follow instructions
Enter initial registration
Set dates of statutory inspections
Set in car date
Reset the average mileage
Enter service telephone numbers
Erase fault memory
Carry out brief diagnostics test and rectify faults
Tyres;
Check tyre pressures and pressure of compact spare if there is one
Initialise the run flat indicator
Protective coating, cleaning
Remove protective packaging
Remove protective coating and clean car as per directive
Put all docs in car or hand to customer
Owners handbook
Service booklet
Contact booklet
Looking after you car
BMW group mobile service booklet
Remote control, with integrated key and spare key
Stickers
Affix BMW group mobile service stickers
Indicator warning lamps and check cntrols
Check for fault display and rectify if required
Body, interior equipement and underside
Check for damage during transport
Engine Compartment
Cehck for cleanliness
Washer Fluid Reservoir
Check fluid level and top up if neccessary
Content of equipment pack
Install
Spring Loaded Retainers
Remove
Battery ON/OFF Switch
Remove and carry out the follwoing operations, if applicable
Power windows - Initialise system
Glass sunroof - Initialise system
Initialise steering angle calibration
Winter tyres
Attach V-max labels
Service Barake and handbrake
Transport and parking times 3-6 weeks
Test funtion when car is in motion
Exceedding 6 weeks
Apply the brakes
Hope this is what you were after
Old Jan 7, 2007 | 07:44 AM
mini-s-man's Avatar
mini-s-man
Thanks for the detailed list R56MCS - especially since it looks like you may have typed it from the the service book!
I suspect this info may be a very helpful service to many members of NAM
I'm so used to seeing a maintainence chart that perscribes what actions are necessary every so many months or miles. Knowing the frequency allows one to plan/schedule/budget accordingly. Do you have any idea how often the average/typical MCS owner will need to bring their car in for service?
Are there any specific service requirements for:
  • The turbo/intercooler
  • The optional: LSD, Stability control, or Xenons?
  • Those of us who plan to keep our cars on the road for 100k to 300k miles?
Thanks again!!!!
Old Jan 7, 2007 | 08:48 AM
R56MCS's Avatar
R56MCS
This is indeed from the service book, there are no specific things mentioned in this or the owners manual for the turbo, LSD or xenons and thinking about it I cannot really see what would need doing as preventative maintenance.
The service indicator, which displays briefly every time you start the car, has a number of messages it can display using different colours and indicators. These tell you what needs to be done. The service book itself has tick boxes for what work was done and at what mileage.
As the above states that statuatory insepctions are programmed in the pre delivery service I assume that these will be annual checks. If you have the TLC pack the 1st of these is included.
Check the TLC pack and what you get in it as this has changed from the R53 to the R56.
I expect services to appear about every 20k miles, based upon the TLC package.
Old Jan 7, 2007 | 09:08 AM
mini-s-man's Avatar
mini-s-man
Thanks again Legio!
Old Jan 7, 2007 | 10:20 AM
R56MCS's Avatar
R56MCS
Legio Patria Nostra is my old regimental motto, not my name which is Scott.
Old Jan 7, 2007 | 11:10 AM
mini-s-man's Avatar
mini-s-man
Hi Leigo,
Yes, yes, French Foreign Legion "Legio Patria Nostra" Latin
"The Legion is our Fatherland"
Thanks again Scott
Aug 19, 2015 08:22 AM
Aug 14, 2015 01:45 PM
Aug 14, 2015 01:44 PM
clintmeister
Aug 12, 2015 11:11 AM
