R56 Car not starting after changing valve cover
Old Dec 7, 2022 | 09:33 PM
punter22's Avatar
punter22
Hello,
Changed valve cover today and accidentally over torqued the ground bolt and snapped it. Car won't start now tried to ground directly to the case and to no effect.
Not sure if I blew the ecu?
Old Dec 21, 2022 | 02:12 PM
techman1's Avatar
techman1
I seem to recall that ground is needed for the coils to fire. I also recall something, possibly shorting out if it is not grounded.
Old Dec 21, 2022 | 09:33 PM
mkov608's Avatar
mkov608
The ground is required for the coils to fire since it's the ground path for the coil primary circuit, but you won't damage the ECU if it's not connected; if it's not connected, there's no current flow in the coil primary; if there's no current flow in the coil primary, the secondary will never fire.
The ground is X64561.
Here it is in the schematic (see red arrows)
The yellow (coil 3), white (coil 1), blue (coil 2), and orange (coil 4) are the ground-side switched wires from the DME (engine computer). The green wire is the system voltage from the DME.
Did you remember to plug in both the inlet and exhaust camshaft position sensors? Those connections are on the valve cover, and the engine won't start without a camshaft signal.
punter22
Feb 2, 2023 10:09 AM
scubus
Aug 30, 2021 07:58 AM
genik
Dec 13, 2018 02:15 AM
