R56 Need Help! P0507
Old Apr 5, 2021 | 06:43 AM
r56_tyler's Avatar
r56_tyler
Need Help! P0507
Hi all,
After replacing my thermostat I went to clear all existing codes but I received a P0507-(Idle Air Control System Higher Than Expected - Engine Speed too high). I've been chasing around what I believe is a vacuum leak but I have zero idea where its is coming from. The RPM generally stays at 1750 but will drop down close to idle then will almost bog down and stall out. While I was replacing the thermostat I replaced the intake manifold due to cracking and I also replaced the PCV hose that comes out the back of the valve cover. The vacuum pump and HPFP are brand new and I have data logged both and they seem to be working just fine. Any input would be greatly appreciated.
Thanks,
Tyler
@r56_tyler ig
Old Apr 6, 2021 | 05:03 AM
scotty_r56s's Avatar
scotty_r56s
Have you checked the electrical connectors on the thermostat housing? From what I've read, these can be mixed up with one of the other 4 pin connectors. I didn't have that issue when I changed mine, but apparently, it happens.
Old Apr 6, 2021 | 05:49 AM
r56_tyler's Avatar
r56_tyler
Ill check a wiring diagram and confirm, thanks Scotty!
Old Apr 22, 2021 | 11:15 AM
r56_tyler's Avatar
r56_tyler
*UPDATE*
After further investigation I found a few things.
1. PCV hose had a crack when replaced I saw a drop in a few hundred RPM but still had the same code after clearing
2. Fuel tank purge valve hose also had a crack replaced and still had a the code after clearing
3. Main connecting port to throttle body was split in half replaced throttle body, cleared codes haven't returned since
Car ran fine for a few days never took it out received another code P0303 so now im on the hunt to find out the cause for this one
Here is the new thread I started for this misfire: https://www.northamericanmotoring.co...oss-p0303.html
guruerror
Dec 13, 2019 04:53 AM
Piercems3
Sep 17, 2019 09:00 AM
58caddy
Nov 7, 2018 08:54 PM
scott13
Nov 7, 2015 12:45 PM
ColinMc
Mar 2, 2012 09:20 PM
