R56 Front brake pipe replacement
Old Feb 22, 2021 | 10:52 AM
HHMCS's Avatar
HHMCS
Hi all, went to swap my brake hoses out and the nut is seized to the brake pipe. Ending up snapping the drivers side pipe as it twisting with the nut and the other side isn't much better despite lots of penetrating oil.
Got some new pipes on order and wondered how straightforward it is to replace, as in what is best to pull out for access?
For the passenger side, can you actually undo from the hose connection as opposed the top nut? Any other ideas for undoing without cutting off appreciated!
Cheers...
Old Feb 23, 2021 | 09:23 AM
danraabe's Avatar
danraabe
Goog Luck my friend. After twisting both pipes off of the rear brakes because they were seized on, i found bendable solid brake lines, the proper fittings and a small tool to make the flair - all online. The flare is critical and mini uses them on all these lines. The brake lines from the dealer sometimes come in straight lengths and impossible to bend without the proper tools.
elightbo
Mar 15, 2021 12:52 PM
MINICS04
Mar 15, 2021 10:38 AM
CSP
Feb 14, 2017 01:39 PM
micromini234
Jun 6, 2013 02:39 PM
Porthos
Sep 8, 2011 01:01 PM
