R57 Brakes
Old Dec 18, 2020 | 02:04 PM
Capt ken's Avatar
Capt ken
Brakes
Did a unexpected hard stop. Ever since brakes have been going half way to the floor before catching. They do pump up. Assuming it is the master cylinder because I do not have any abs or other warning lights. No leaks that I can see and reservoir is full. Anything else I should check before replacing the MC? Reading Bentleys, do I really need the scan machine tool to bleed the abs/brakes after changing the MC? Have both a pressure bleeder and a mityvac. Prefer the vac bleeds, lot less messy.
Old Dec 29, 2020 | 03:32 PM
Capt ken's Avatar
Capt ken
more info
Do your flushes. it took a couple days to find a new master cylinder. Not an easy job to change the MC. Airbox/engine computer have to be pulled with associated ducting. Old fluid looks like a weak cup of coffee. Probably original fluid. Mityvac did not work. Need a pressure bleeder. Pulled mine out and set to work. Initial flush was good, old fluid and lots of bubbles. Pedal still feels a little soft in the garage. Will give a road test tomorrow. May need an old fashioned pump up the pedal hold and bleed as a final procedure, saw something about that in bentleys, but got too late to investigate more.
crazyworld
How to
22
Sep 6, 2016 01:53 PM
cpoerschke
Nov 16, 2012 10:36 AM
killasha
Apr 15, 2009 01:42 PM
89AKurt
Nov 12, 2007 07:53 PM
D3m0N
Eastern Iowa MINIs
Nov 2, 2007 07:17 PM
