R56 Sudden misfire
Old Apr 8, 2018 | 05:28 AM
Ahmed Hisham's Avatar
Ahmed Hisham
Sudden misfire
Hi
My car yesterday started misfiring like crazy all of a sudden. Cylinders 1,2,3 are all misfiring.
I have had my spark plugs changed only 6000 miles ago.
My OBD reader says the fuel rail pressure is OK.
Any Ideas?
Old Dec 20, 2022 | 09:20 PM
redwhiteR562007's Avatar
redwhiteR562007
Check the ignition coils. There is a coil on each plug. My 2007 R56 suddenly showed misfire on Cyl 1. Turned out it was a bad coil, changed the coil, running fine.
Check it out here:
Old Dec 21, 2022 | 06:05 AM
DogfaceSGM's Avatar
DogfaceSGM
Mine started doing it yesterday, cylinder 2 only. It wasn't throwing a code till it did it and I kept the accelerator to the floor. If I backed out of it, no code. When I stayed in it, it continued to miss then threw a code and went into limp mode. Checked the codes and cylinder #2 showed.
Old Jan 3, 2023 | 08:03 AM
DogfaceSGM's Avatar
DogfaceSGM
Update,
Swapped cylinder 1 & 2 coils and the misfire followed the bad coil. Replaced the coils this weekend, car runs great again! New plugs finally arrive today so perhaps next oil change, I will replace the plugs.
Old Jan 3, 2023 | 10:00 AM
rvidal's Avatar
rvidal
I had several multiple misfires (random) and so far it looks the Diverter Valve was the problem( S R56 model). If bad, avoids the extra boost to be returned to the compressor inlet, affecting the air/fuel mixture giving misfire codes and putting the car in a kind of "safe mode" with 4000 rpm limit. No engine light.
Old Jan 10, 2023 | 12:57 PM
techman1's Avatar
techman1
If the misfires are all cylinders, and there is a code relating to timing, might want to check when the timing chain was done.
BBRaven
Jun 25, 2021 05:11 AM
shipjumper
Oct 8, 2018 06:25 AM
seamusnh
Mar 14, 2016 07:43 AM
PSUMINI
Jun 1, 2014 01:18 PM
aDeLoreanGuy
Dec 8, 2010 04:11 PM
