R56 Replacement turbo inlet pipe for a 2012 R56 S n18
I have a 2012 R56s and I’m interested in replacing the turbo inlet pipe. All the replacements I find do not fit the 2012. Any suggestions?? Thanks
If you go with an aftermarket you have to bypass the sensors from the stock hose. So I would just stick with the stock one as there isn't a power gain from it.
https://www.waymotorworks.com/oem-mi...9-r60-r61.html
but if you want an aftermarket we use the Forge
https://www.waymotorworks.com/forge-...9-r60-r61.html
Drivetrain Introducing From ALTA - R56 Turbo Inlet Pipe
ALTAPerformance
Oct 28, 2015 02:18 PM
Drivetrain Alta R56 S Turbo Inlet Hard Pipe?
Dwight Walhood
Apr 17, 2010 08:36 PM
