R56 Did you notice this!!! timing chain
Old Nov 3, 2017 | 07:23 AM
MiniToBe's Avatar
MiniToBe
I bought two timing chain kits, one for the N18 (2011+) and one for the N14 (2007-2010). Aside from the top and side guide rails being different, I noticed the timing chain on the N18 engine is 3 links shorter!
I was wondering, why not use the shorter chain on the N14 engine and not have to worry about slack anymore?
Old Nov 3, 2017 | 08:03 AM
ashchuckton's Avatar
ashchuckton
I'd guess using that shorter chain will screw up your valve timing. Do that in you are going to have lots of fun.
Old Nov 3, 2017 | 08:23 AM
MiniToBe's Avatar
MiniToBe
lol...I just ask a friend of mine and said the same thing...I guess i wasnt thinking about the timing, but rather the slack of the chain.
case closed, i guess
Old Nov 3, 2017 | 08:36 AM
DneprDave's Avatar
DneprDave
All timing chains are designed with a small amount of slack. The chain tensioner takes up the excess slack as the chain wears.
Old Nov 4, 2017 | 06:23 AM
gjxj's Avatar
gjxj
the length of the chain would not affect the timing, so long as the tensioner could accomodate it it would work in principle.
Old Nov 4, 2017 | 06:51 AM
scottyb043's Avatar
scottyb043
Wouldn't the tooth count on the sprockets be matched to the number of links in the chain? Sorta like the tooth count on a ring and pinion determines the ratio.
